5 ton 4 wheel question
Westex
El Paso, TX
Anyone have thumbs up, or thumbs down on the 5 ton 20 foot pintle hook trailers for a Deuce? Am thinking about buying one just for hauling whatever behind my Deuce, like welder, ATV 4 wheeler, etc. ??
number9
Lexington, KY
It'd be an awful big and heavy trailer to haul the things you mentioned. Maybe if you were going to haul a bobcat or backhoe or a vehicle. An M105 would haul the things you mentioned much more hassle free I'd think.
Westex
El Paso, TX
That's kind of what I was wondering. I might haul my bobcat (a small one) once in a while. Didn't mean for my first post to be misleading. I guess I'm wondering what one of these trailers weighs empty?
Nonotagain
Parkville, MD
If you are talking about the M1061A1 5-ton trailer, they weigh in at 5800lbs pper the data plates on my trailers.
Now if you are asking abou the M105A2 trailer, the are 2750lbs +/_ 50 lbs.
You would be hard pressed to get a Bobcat into a M105 trailer unless you got a M105A3 due to the wider wheel wells. As for the weight, the 853 Bobcat that I have weighs close to 7k, not something I would put into a M105 trailer. Some of the smaller Bobcats are in the 5k weight range.
Stretch44875
Super Jr. Moderator
32
Tiro, Ohio
M1061 are 12ft, m1061a1 or e1 are 14 ft. Search 1061e1 and you will find more info. I have one and like the shorter deck height, tarp frame, and sides I built. Useful trailer to have, just need to build ramps.
Westex
El Paso, TX
I'm looking at the M106A1 trailers, and thanks, Nonotagain for the weight info. I have a 753B Bobcat with a bigger diesel I put in it and it weighs about 6,000 lbs.
bassetdeuce
Orange City, FL
I am recovering one M1061A1 from Ft Jackson right now, and I'm headed to see Clinto tommorrow. I didn't care much for them at first, but now I see they are neat little buggers. My 5.9L Cummins RAM 3500 dually pulls it with ease, although when loaded I will prob use the M818 for better braking.
Green_gator
Tampa, Fl
Westex,
Take a look at the M353 series of trailers. It can handle 7,000 lbs and is much lower to the ground. Just not sure if it is wide enough for the bobcat.
