24 volt to 12 volt
itsunday25
pennsylvania
hi i got a 1985 m1010 it dose not have the box on the back no more just a flat bed.i would like to make it all 12v cuzz i have had wiring night mare sins i got it a year ago i had it fixed and now the back battery is geting 16.45v and the front is not geting nothing. i give up just going to go to 12v what do i have to do i can get a civil blazer 6.2 could i use the under hood wiring or can i ues the wiring that is in the truck now idk what to do please help thanks.
Barrman
2,121
Giddings, Texas
There are several threads on here about converting to all 12 volt. You will need to find a civi 12 volt starter. Everything else will be changing where a few wires go. Very easy to do.
However, you won't be able to jump another mv off or be jumped off. I would suggest a single 27si alternator and both batteries wired in parallel.
Warthog
241
OKC, OK
There really isn't that much stuff that is 24v.
Here is a breif recap:
change the battery wiring - (are you removing a battery?)
change out the starter
remove resistor from the volt meter
remove/bypass the GP resistor pack
change the wiring for the alternators
change out an alternator with a regular 12v
remove the voltage regulator
There is a company that does this on 1008s and 1009s for Fire Departments. I can't think of the name right now. Rosco....something.
http://www.roscommonequipmentcenter.com/news_notes/nn10.pdf
Here is another post that covers it
http://www.steelsoldiers.com/cucv/27673-convert-m1010-electical-12v-details.html
Just remember, if you do make changes and have issues, not many people will be able to help diagnose the problem.
Good luck, Mr Phelps.......................
tourus
madison me.
12volt
I to have a 1010 i converted to 12 volt all i did was get 2 lesnaville alt s bolt right in the acdelco will not just jump in so lesnaville buy pass the fire wall resiter put 12 volt starter on . That was 3 years ago no prombles since very easy . Then i run a wire from each bat to each alt .moved on been great 320 amps under hood so what one can not jump start another mil truck so that is the easist convert on the site
doghead
4 Star General /Moderator
1,191
You would need the underhood and in cab harness, to use the other trucks harness.
It would be easier to modify what you have, if you want to go to 12 volts.
