Two questions if you guys know?
MuleMac01
Military vehicle collector
185
Las Vegas Nevada
today i was cleaning around my Radiator reservoir and i found a strange wire or cable thats not connected to anything have you guys seen this or can you tell me where it gos? all my lights / horn / blackout lights work
secound i found a secound radiator reservoir cap. can anyone tell me what is the right stock cap? They both work and fit?
Old Truck Guy
Lancaster County, PA
That looks like the wire that plugs onto the brake distribution block that would power your brake light in the dash. It plugs onto the block attached to the front cross-member below the radiator. You might have to craw under and look forward. The cap I can't say. I'll look in the daylight and see what mine is like. Hope this is of help.....
rlwm211
19
Guilford, NY
The radiator overflow cap on the left is the correct one.
It appears you have some light unplugged from wherever it is supposed to be plugged in. That is if the other end goes to a light of some sort.
RL
boomer431
trinty,nc
The wire is for the brake proportion valve . It plugs into a bracket on the frame and then to the proportion valve which is under the radiator.
EMD567
Driver for the Ga Mafia
Aiken SC
The cap on the left is for overflow tanks that do not have a overflow port. The one on the right is for tanks that have the overflow.
3dubs
Houston, TX
Hope you can see it next to the hard lines. I found the same wire. I never really cared what it was for. I had another truck to look at figured it out and plugged it in.
MuleMac01
185
Las Vegas Nevada
Where is your overflow bottle located? Mine is located on the drivers side next to the radiator and i believe it has the cap on the right. My 88 R30 crew cab and my 89 k-5 both have the cap on the left
its on the driver side i took it out 2 show people:
3dubs
Houston, TX
It may be hard to see in the pic. It is dark outside. But the wire plugs in on the driver side frame behind the radiator and in front of the hard lines. Take a look and you should see a plug on a bracket.
MuleMac01
185
Las Vegas Nevada
mine has the bracket but not the other wire to the brake proportion valve ( it's the valve that controls both brakes correct?) if i dont have this connected is there going to be a problem?
PS. i seen that there is a rudder cap i'm guess in place of the sensor prob another military fix it
Crash_AF
Colorado Springs, CO
If you look close at the rubber 'cap' you'll see a line because it's supposed to have a spade terminal sticking out of it and it probably got busted off.
The only thing the wire is for is to turn the brake warning light on on the dash if you have a failure in one side of the brake system. Without it, the light won't come on to warn you of a problem with the brake system.
If you're observant and can notice that your brake pedal got a lot more travel and turned to mush, you might be able to safely do without the light.
Later,
Joe
MuleMac01
185
Las Vegas Nevada
Later,
Joe
crap well i dont see any wire's coming from it crap maybe the militarys guys went for some joy rideing though some brush and it got riped off anyon e know where i can get a new brake proportion valve from ?
3dubs
Houston, TX
I connected mine just to make me feel better but I do not think it is important. I found it in the TM's but it took searching and I do not remember what it was.
