M35a2 additional alternator
blisters13
68
Beaumont in SoCal
I mounted my 12 volt alternator right above the stock 24 volt. I used longer belts and a replacement double pulley from a IH 966 tractor. The alternator seems to fit well in that place and so far neither pulley slips even though there is much less belt contact on the 24 volt pulley.
You won't have a slipping-belt problem as long as the batteries are generally well-charged. Slipping belts are more likely to happen with more discharged batteries as more torque is required to put out more amps.
Nice set-up. GM alternator? Which one? Part numbers for longer belts?
graf_222
Hokah, MN
Yup, just a 10SI GM alternator. It is the 63 amp version from a 1986 K10 pickup.
As for the belts, I used two Dayco 17570, but the length needed will depend on how close the alternator gets placed to the engine.
blisters13
68
Beaumont in SoCal
Gotcha! It does help to know the belt length since you already have a successful install and so other people will have a benchmark to start with. Thanks for the post!
tm america
23
merrillville in
i sell the brackets you need to to install a 12 alt on a multifuel.. i have them listed in the classifieds..the price is 50 plus 10.70 shipping they use a 10si alt
tm america
23
merrillville in
The 12 volt alt uses a 55 inch long 1/2 inch belt ..So the numbers on the belt will be 4l550 or l455.the 12 volt alt brackets work with either a 10si,12si,or 130cs alt....The 24 volt kit uses stock belts
