Mystery Winch Part
Tinwoodsman
77
Comfort, Texas
I began the overhaul of my 10K winch today and came across a part I cannot identify. The TM shows it in the illustration but it is not referenced. I is a hinge of some type and mine is somewhat bend with a small hole in the hinge plate. It may be broken off but I am not sure. What is it and is it critical to the operation of my winch?
Tinwoodsman
77
Comfort, Texas
Great. Do you just flip it up to go against the lever or how does it work. Can you tell from my photo if mine appears to be complete and what is the hole for?
Recovry4x4
LLM/Member 785
1,827
GA Mountains
All deuce winches came with it. Just flip it up and it blocks the shifter from moving. Might need to juice it up to get it working smoothly.
runk
66
Houston, TX
And if its stuck back over too far, and bent just right, its just perfect for nicking a nice little hole in the radiator you're removing / installing (right through the cardboard you thought would protect the radiator...)aua
OSO
Arlington,Wa
Sounds like it hurt!!:(:(
Recovry4x4
LLM/Member 785
1,827
GA Mountains
Similar lesson learned! Use masonite to protect radiator.
Jake0147
Panton, VT
Tinwoodsman, my winch did not come equipped with this piece. I intend to make one, it's not that complicated, but I wonder if i could trouble you for another picture with the latch flipped up, that would show how it's properly mounted, and how it sits against the lever when it's in use.
