Patattack
- 16
- 18
- Westminster, md
quick ? my rear diff oil seal is leaking, do i order the seal off a k10 3/4 ton cuz the civi blazer is 1/2 ton, its sounds like a stupid ?, but i just want to make sure, thanks
Any pinion seal for a 10 bolt g.m. corp. will work. The only difference between 10 bolt 1/2 & 3/4 tons are the hubs. (8 lug vs. 6 lug) . The M1009s & civi. blazers are the same except for the spring pack. RTV will not work on a pinion seal, but they seal up a rear cover just fine instead of a gasket.yea the back were the driveshaft connects to, i hate using rtv, but if i cant find it i guess ill have to.
Just go to any parts store and ask for parts for a military vehicle. They will be more than happy to help you.quick ? my rear diff oil seal is leaking, do i order the seal off a k10 3/4 ton cuz the civi blazer is 1/2 ton, its sounds like a stupid ?, but i just want to make sure, thanks
WOW..... not making friends with a response like that....CAIM DOWN warthog im just asking a simple question. im new at this ok im used to putting nsn on paper or ordering parts for civi trucks. i didnt know u could do that, thanks for pointing that out for future references,![]()
