Erik Jenkinson
- 9
- 18
- Alpharetta GA
I was reading about removing the bell housing on my m1009 to torque my torque converter bolts into spec. I then noticed an about 3/16" hole drilled into the bottom of my bell housing. Couldnt find anything in the tm. Is this factory? If so, what is its purpose? Also, can I remove it, pull the bolts , and loctite them in without draining the tranny (obviously I never have done this before) I also see 8 bolts where the tm only shows six holding it on.
