truck identification
m16ty
223
Dickson,TN
Find the frame number and have carnac run it in the 2011 vin info thread
pictures will help nobody has any idea without pictures
:ditto:
The frame number will tell all. I've seen many trucks with the wrong data plate.
Rustygears
Ramona, CA
Mine is behind front axle on driver's side written in WELD on the frame rail. Easy to spot, easy to read. I'm thinking of painting the raised weld bead to highlight it. 'Dunno why, just want to.
CARNAC
The Envelope Please.
697
Corpus Christi, TX
The vin is stamped into the frame. Check the frame rail at the drivers side front. Found this using search function, theres also pictures if you need them.....
(Que the alarm sounds)
CAUTION, CAUTION, CAUTION: CARNAC IS HAVING HIS TIME OF THE MONTH--I MEAN DECADE.
CAUTION, CAUTION, CAUTION: CARNAC IS HAVING HIS TIME OF THE DECADE.
AND IN ADDITION TO SEARCH, IF ANYBODY BOTHERED TO GO READ POST #1 AS STATED EARLIER, IT SAYS EXACTLY WHERE TO GO TO FIND THE FRAME RAIL VIN NUMBER.
and in addition to that,
FOR GOD SAKE, AND THE SAKE OF THE PEOPLE YOU ARE SHARING THE ROAD WITH, READ THE TECHNICAL MANUAL. SPELLED OUT SINCE I DON'T WANT TO HAVE TO ANSWER WHAT TM IS.
598
Karlsruhe, Germany
On older models the VIN can also be stamped on the passenger side to the right of the shock mount (looking straight at it).
On my deuce, this is the case. The VIN was buried under many coats of paint and not easily visible. Don't sand the paint off with a grinder if the VIN isn't visible or diffuse, as it might ruin the stamping. I used liquid paint remover and thinner.
Cheers,
Mark
CARNAC
697
Corpus Christi, TX
Mark,
Dies war der sinn meiner aussage. Die menscher mussen zu suchen! Dies informationen werden in post 1.
Wiedertypen (LOL).
zak
-4
Ortonville, Mi
It also sometimes helps to pin down an approximate ( notice approximate) year by checking all three axle tags or stampings for build dates. If all three are the same, then probably ( notice probably) this an approximate ( notice approximate) build date for the frame and axles. Motors and trans come and go but frames stay the same.
m16ty
223
Dickson,TN
Carnac, I'd be glad to post my VIN on your thread to find out the year but I need to know where to find the number on the frame.
I'd also like to know where to check my brake fluid if you happen to know.
JUST KIDDING. Please don't blow a gasket. :)
Also, thanks for the work you do on the VIN info
jaxsof
15
Dundalk, MD
:ditto: And would you happen to know how big a tire I can put on this thing and make it fast!?
Leider Carnac, musste ich einfach
G-Force
allendale nj
You can also take a DNA sample from your truck and submit it to CARNAC for testing.............but lately due to his mentsl meltdowns it may take longer than expected to get the results back.....:razz:
