Multifuel bearings
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
So some of you may remember I snapped the crank in my wrecker's original motor. I have acquired another crank from another multifuel. When we took it out, the bearings looked good. I am thinking about re-using the bearings. I will be calling to see how much a set is, but I'm willing to bet its big $$$. How stupid would it be to not get a new bearing set? Anyone have a set.
porkysplace
1,496
mid- michigan
I realize funds are tight for everyone here ,but would feel alot better with new ones if it was mine . They are a key factor in the oil pressure for the motor .2cents
Ruppster
Member of questionable origins
608
14
Lakeland, Florida
When I learned how to rebuild engines I was taught it was okay to re-use bearings as long as they were in spec and went back to the same journal on the crankshaft as they have become a matched set. Same with lifters and cam lobes on a V8 gas engine. Since the bearings have worn some to become matched to the crank it would not be a good idea to use used bearings on a different crankshaft altogether.
But that's what I was taught. Have I tried it first hand to see if it really makes a difference? No, afraid not. :)
Ruppster
Warthog
245
OKC, OK
Use some Plastigage and check the wear patterns.
You have enough time on your hands that if it does crapout then you can put in new ones.
porkysplace
1,496
mid- michigan
I would guess the first thing to do would be get some plasti-gauge strips and check the tolerances on the used bearings.
edit ; warthog beat me to it
466Navastar
Buffalo,ny
keep all the bearing tops and bottoms on the same journals as they were on in the old motor ....if they arent showing copper and arent grooved - on a grooved crank journal - why not try....plasti-gauge
although its a lot of work to get back and change them later......unless the crank is perfect- and unless you are really on a shoe string budget ---the right thing would be to take the crank in and get it turned and polished and replace all the bearings - crank and rods.....then you can pretty much forget about it for as long as you own it.....
it really dollars and cents and how much you hate the thought of pulling a motor again....
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
That's interesting, a LDS motor with a cracked crank is sitting in my pole barn. What are the odds? Want to come fix it?
Westech
CPL
6,104
212
cow farts, Wisconsin
If you use the bearings that come with the crank go for it. Just make sure you keep them in the SAME place. you mix them up there good as gone.
Should have called me first and saved a post ya noob.
I thought I was on "someones" ignore list.. guess not. So i will be waiting on HOW ITS A BAD IDEA AND THE WORLD WILL END response.
Love Westy
hndrsonj
Senior Chief/Moderator
371
Cheyenne, WY
I am pretty sure there were some on ebay under M35A2.
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Yep, along with the sandblaster, compressor, and generator motors. Maybe I should rename the barn Gimpy north? One of these days we'll get'er done.
Get the crankshaft out of the truck yet?
m16ty
228
Dickson,TN
Bearings are generally cheap for engines. I've seen brearings for other engines of similar size for less than $200. I'd call around to the usual sources and price a set. Unless they are crazy high for some reason, I would replace them. If it was the same crank I wouldn't be too worried about it but with a different crank I'd be afraid it may cause problems.
Billy Bobbed
13
Terre Haute,Indiana
I have been grinding crankshafts for over 25 years,their is nothing wrong with reusing bearings as long as you keep the bearings that came off that rod or main together and they are in good shape.Just remember that bearing does not touch the crankshaft.The film of oil then oil pressure keeps it from touching the crank.I have people bring me bearings that have been in an engine with 150k or more miles that look like new.I do alot of antique tractor puller cranks that cant get new bearings so I have to try and keep the rods or mains the size it is or weld it back to the size bearings they can get or have.
