transmission fluid dip stick
cjm82
Mahwah, NJ
I checked the the transmission fluid today on my M35A3 and when I pulled the dip-stick the fluid shot up the tube like it was under presure. Any ideas why this would happion?
Floridianson
2,531
Interlachen Fl.
Yea I do believe one of the three vent tubes is clogged. Under the truck there are three small black tubes if I rember run up the back of cab. Find the one that goes to the trans and suck it out. I would not blow into it but try and suck it out or disconnect it from trans and then blow it out.:driver:
mktopside
Banned
467
Gainesville, Va
Yup, vent tube is clogged. Have a friend crawl under the truck and find the vent tube on the side of the transmission. Have him jiggle the tube so you know which one of the hoses on the back of the cab it is. Blow some compressed air through that tube with the trans dipstick out....... = "Winning". ;-)
Floridianson
2,531
Interlachen Fl.
The only reason I dont want air blowen into the trans is if its a muddobber you will push the mud into the trans.
Your call!!!!!!!!!!!!
mktopside
Banned
467
Gainesville, Va
It's a valid point.
I was changing my trans fluid at the time so I didn't care. But I will tell you that when that hose is plugged that dipstick tube will shoot trans fluid all over the can if you try to fill it.
Floridianson
2,531
Interlachen Fl.
It's a valid point.
One key to the left. Now I don't feel so bad about my spelling and quick typing. Thanks I will watch my can.:driver:
