coondog
- 0
- 0
- Fall River/KS
I'm wanting to install a keyed ignition switch, and I need help. Like Type of switch, what to remove and how to wire up new switch.
I've had some troubles with the ignition switch not starting the first or second times. Then today it left me stranded as truck would not start. Checked the battery cables all were tight. Pulled the caps off of batteries and they were boiling inside with the switches off. Pulled the batteries and checked them and replaced one. Reinstalled and the sparks flew, with switches off. I've checked other treads and will work on the starter. I still want to install a keyed ignition switch. THANKS
