2011 vin info thread
CARNAC
The Envelope Please.
713
College Station, TX
Thanks for what you do CARNAC. My information follows:
1986 M1009
a. (VIN) 1G8ED18J4GF141247
b. (Reg #) NF0H99
c. (NSN) 2320011232665
d. Recovered from Nellis AFB, NV
e. (Bumper numbers) Multiple, please see below.
Ancillary information: I don’t know if any of this is helpful at all but I thought I would include them since I can read them.
Bumper, rear drivers side and both sides of front, most recent: 913BDE
Bumper, rear passenger side, most recent: C5133
Bumper, rear drivers side, original? (in CARC): 124CR373NH
At the top of each of the four wheel wells: TP-35 (the dash literally stenciled on)
In the door frame, an Army reserve inventory sticker: ECS170000002105
Thanks again, and I hope I didn’t bombard you with meaningless numbers. Again, it’s just all the stuff i could read.
Organization:3D BATTALION, 356TH REGIMENT Location:FT HUNTER LIGGETT
CA
Nomenclature:
TRUCK UTILITY 3/4TON Model:
M1009 NSN:
2320011232665 Serial Number:
J4GF141247 Registration Number:
NF0H99 Year of Mfg:
1986 Manufacturer:
93219 Contract Number:
DAAE07-82-C-4060
Usage Miles: 28860
Sep 04 Prior to this date, it was with the Headquarters, 40th Armor Division California Army National Guard.
CARNAC
713
College Station, TX
I'm feeling a little stupid here...
I have done MANY searches trying to find the "Correct" information needed.... Can't be sure I've found the right data...
I have an M275 Road Tractor. (This was my FIRST MV) Some years ago (about 8 or 9... I can't remember 'exactly' ) I found it in a back lot of a sawmill under some logs and it had some trees growing up through it... They said it was purchased years ago, no clue when or where, but that it had sat in THAT spot for at LEAST the last 10 to 15 years... Got it out and though it is is in terrible shape, it does have a hard top and after minimal clean up, it RUNS..
The entire truck was painted white and I was told that that's the way it was painted when they got it.. after much pressure washing and a little sanding, I was able to see that the hood was at one time stenciled US ARMY (and still is under some coats of paint) but don't see any other numbers there... The front bumper was torn up, with both sides broken off... One piece was inside the truck and I found the other piece not too far from where the truck was sitting...any numbers etc that may have been on them are gone...
I was trying to get my data numbers together for you to see if any history on it can be found, but when I went to enter the numbers, I realized that what I had didn't match up to what is very specifically required...
Not sure exactly which numbers are correct for your use...??? NSN what ?
I was HOPING someone else here had gone through CARNAC with their own M-275 before and could help me out but after doing a boatload of searches have come up with little...
The motor is an LD-465-1 and it has a turbo...
On the dash, it shows
Truck, Tractor, 2 1/2 Ton, 6x6 Multifuel M275
Stock No 2320-446-2479
Ser. No. M275
Mfr. Ser. No.165134 Model TK-D-42
Cont. No. FEB YR. MFD. 1964
DA-20-018-AMC-0398T
On the drivers side frame to the front of the axle is stamped 68 92L 10 32
On the drivers side frame to the rear of the axle is stamped 165134
So I am presuming that the Mfr Ser No is the VIN since it is stamped on the frame?
It was also recommended to me that the Stock No would be the NSN if I added two 0s between the 2320 and 446...? The plate shows 2320-446-2479 but I was 'informed' that it 'should' be 2320-00-446-2479???
So here goes my best effort at giving you what you require...
a. Serial Number (VIN number) ------165134
b. Registration Number ----don't know
c. NSN without dashes ----- 23204462479 or 2320004462479
d. Where you bought it Found it off Route 1, 11 mines north of Ashland Virginia
e. Bumper numbers if you can legibly read them.. none
Thanks for anything you can find![thumbzup]
Think we handled this on another thread.
Lawrence of Arabia
Howell MI
Possable Typo
05A91971C12710799, Can you try this VIN? This is the VIN GL had recorded, but the dash clearly shows 06A...............
1971 Am General 5Ton M816 Wrecker
Bought from GL
Recovered from Wright Patterson
VIN or S/N: 06A91971C1270799
NSN: 23200510489
Service No: 8736857
Miles: 38,503
Thanks
flyusn99
Oak Harbor, Wa
M35a2 w/w
CARNAC,
Two trucks I was hoping to get checked out, info as follows:
a. Serial Number (VIN number) -053910930
b. Registration Number ----- 04E93171
c. NSN without dashes ----- 23200771617
d. Where you bought it: NAS Jacksonville, FL
e. Bumper numbers: Passenger side: 113 AVN Drivers side: C7
Manufacture: Jeep Corporation
a. Serial Number (VIN number) -032526143
b. Registration Number ----- 04A11370
e. Bumper numbers: Passenger side: 113 AVN Drivers side: C20
Manufacture: Kaiser Jeep Corporation
Thanks for your help.
James
CARNAC
713
College Station, TX
Bought from GL
NSN: 23200510489
Service No: 8736857
Miles: 38,503
Thanks
Organization:WV OMS 1 Location:CHARLESTO
WV
Nomenclature:
TRUCK WRECKER 5-TON Model:
M816 W/W NSN:
2320000510489 Serial Number:
C12710799 Registration Number:
5A91971 Year of Mfg:
1971
Usage Miles: 38111
Info is from Dec 96 when the vehicle was sent to A Company 1092 Engineer Battalion out of Point Pleasant, WV.
CARNAC
713
College Station, TX
CARNAC,
James
Organization:US ARMY AVIATION CENTER OF EXCELLENCE Location:FT RUCKER
AL Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 W/W NSN:
2320000771617 Serial Number:
53910930 Registration Number:
4E93171 Year of Mfg:
1971 Usage Miles: 23156
Sep 98
Organization:SUPPLY DIV Location:FT MCCOY
WI
Nomenclature:
M35A2 W/W NSN:
32526143 Registration Number:
4A11370 Year of Mfg:
1970
July 96 when it was transferred to the 597th Ordnance (ATSC) Company.
65 m151a1
Geronimo, OK.
Think this maybe it.
Organization:ARNG TRAINING SITE CAMP SHELBY Location:CP SHELBY
MS Nomenclature:
TRK UTIL (1/2T-4X2) Model:
3200GVW NSN:
2320010907826 Serial Number:
1000031 Registration Number:
CF0123 Year of Mfg:
1978 Manufacturer:
65909 Contract Number:
GS00S56626
Aug 91
Thanks CARNAC for the information. He is making a donationtion. The reason for this is people on the G's say the Mmilitary never had these type of vehicles and I as my self beg the differ because I seen them in the Navy, Air Force, Cost Guard and the Army.
Later Joe
MasterChiefSK
Pensacola/Florida
M101a1
New member here. I just bought a M101A1 3/4 ton 2-Wheel cargo trailer today from Florida Liquidation Center who actually bought the trailer from Government Liquidation Redstone Arsenal Huntsville, AL. I would like to find more information on it since most of the name plate data is blank.
The year and manufacturer is blank on the plate.
Here is the information I have:
a. M101A1
b. NSN: 2330008986779
c. MFR S/N: 4511
The following numbers are stenciled on the front of the trailer and also on the tail gate:
3187CSSB
240D0DS
Thank you for in advance for your assistance.
CARNAC
713
College Station, TX
From a different thread that I know will be eventually brought over here.
Organization:HHB, 142D FIRES BRIGADE Location:FAYETTEVI AR
Nomenclature: TRUCK CARGO 2-1/2T Model: M35 NSN: 2320008358463 Serial Number: M27028
Registration Number: 4C1661 Year of Mfg: 1978 Manufacturer: 58275
We definately know the mfg year is incorrect. That might have been a rebuild date. It's whatever the unit entered.
Info was from Apr of 1986
CARNAC
713
College Station, TX
a. M101A1
c. MFR S/N: 4511
3187CSSB
240D0DS
Organization:24TH AG BN DET B PERS SVCS Location:FT STEWART
GA
Nomenclature:
TRLR CARGO (3/4T) Model:
M101A1 NSN:
2330008986779 Serial Number:
4511 Registration Number:
NW122H Year of Mfg:
1999
Sep 04
PUZZLED
katy, TX
Hello,
M35A2 Deuce, Contract # DAAE0785CJ047
a. Serial Number = 022517063
b. Registration Number = don't have
c. NSN without dashes = 2320000771616
d. Where you bought it = Govliquidation.com - San Antonio, TX
e. Bumper numbers if you can legibly read them = Not legible
Thank you for your service, a donation will be made
leroygreen
Mt. Vernon, IN
Thanks for your help CARNAC.
M35A2 WO/W
a. Serial Number = 04C22069
b. Registration Number = 042515570
c. NSN without dashes = 232000771616
d. Where you bought it = Govliquidation.com - Red River Army Depot Hooks TX.
e. Bumper numbers if you can legibly read them = Driver side reads HQ 304
Support on the way. Thanks again
gunboy1656
24
Beaver Falls, PA
Carnac Please help me find the info for my 2 trailers, I believe both trailers and my deuce came from the same company out of Ohio. Need the info for the SF97 on the trailers.
Camo M105a2:
a. Serial Number (VIN number) --- 65046
b. ??
c. NSN without dashes --- 2330001418050
d. Where you bought it - Wright Patterson AFB
e. Someone wrote on the data plate 558th SC
Green M105a2:
a. Serial Number (VIN number) --- 66274
b. ??
e. 372BDE 983BN ----- 558SC S232T
Looking for manufacturer of them.
Thanks for your time in doing these.
Hawk426
Palm Springs, Ca
CARNAC please help
CARNAC, please help me find out any info you can locate on a M35A2 i just bought. It's my first one and any info would be greatly appreciated. All i have on the title is that it came from Vandenburgh AFB, Ca and Vin # 052517322
Thank You.
swampzr2
Algonquin, IL
1. The more info you provide the quicker I can find your vehicle. Provide as much of the following as possible:
a. Serial Number (VIN number) 04C20871052518709
b. Registration Number ----- ???
c. NSN without dashes -----???
d. Where you bought it ---- Private party
e. Bumper numbers if you can legibly read them --- No visible numbers, it has been re-painted
I was told it was a 1970 M35A2
The data plate on the dash board says:
General products division
Jeep corporation
Stock 2320-077-1616
Hooty481
Russell County Kentucky
M35A2 WO/W
a. Serial Number (VIN number) ------NK023V72052526310
c. NSN without dashes -----2320000771616
d. Where you bought it----- Government liquidation
CARNAC
713
College Station, TX
Hello,
Organization:US ARMY MEDICAL DEPARTMENT CENTER AND SCHOOL FT S HOUS Location:FT SAM HOUSTON
TX
Nomenclature:
M35A2 NSN:
2320000771616 Serial Number:
22517063 Registration Number:
4L6081 Year of Mfg:
1967 Manufacturer:
65909
]Usage Miles: 18789
Feb 98. Congratulations, this was the last known US Army unit to actively use deuces (this does not include installation services or OPFOR or yard whores.
