non- turbo multifuel questions
SCRAP
southern maryland
looking at a cheap non turbo, multifuel duece. it is cheap , runs and has a soft top. what are the differences between my buddies whistler and this one besides engine? is trans and transfer case the same? its so cheap i thought i might buy it to do an engine swap with later thanks in advance for info
NDT
7,266
Camp Wood/LC, TX
LD465 RULES!!! Who needs a stupid turbo??? Lots of power with the NA engine. The rest of the powertrain is identical.
SSG Rock
Macon, GA
SCRAP,
The non-turbo engine will do you just fine. I have just that and it can do anything a turbo engine can do.
SSG Rock
11Echo
96
CT W. R.
This non-turbo truck has been running the trails and pits for several years now. Seems to do well even running the 53" tires.
vtdeucedriver
39
Vermont
I owned one turbo and 2 non and I really miss my NON turbo's. On the long hills, any turbo deuce will out climb you in speed if its long enough but on the straight away, a non turbo deuce will pull away. There is a timing difference between the 2 engines and I believe this is what makes the LD just a bit faster. When I am back on the search for a deuce, I will be preferring another LD. Kept all my spare exhaust parts for the thought.
wreckerman893
Possum Connoisseur
15,644
2,127
I have two turbo deuces and the M275 that is NA.....the little tractor will pull just as good as the deuces......but you have to watch out in a pull if the fuel is turned to it....if you keep your foot in it you can get it hot quick.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
I know owners that have lrft the timing alone and others that have adjusted it. It shouldn't make much difference.
