Diesel generator on WMO?
jimh1985
lizella, GA
My question is simple can the diesel military gens run on WMO? Has anyone here tried it, I don't see why they wouldn't most of them are older style engines.
budman67
Canada (SW ONT)
I asked down in the Genset section if there were any
multi fuel gens,other than the tri fuel,no is what I was
told,they are standard diesel units.I believe the WMO
is to thick,there would be little in savings by trying to
thin it out with diesel and gummed up parts.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
It may very well run on it, but most of us here don't want to try it. The generator typically is used for back-up emergency power. Do you really wanna be the one to find out that the WMO gums up your IP or some other component and makes a back-up piece of equipment useless as a back-up?
Hammer
399
Winlock, WA
I have seen the LDT engine in a genset, but I think it was a 120kw unit.
I wouldn't try it unless I had TWO of them. As stated, they are backup power, and I want/NEED that to be reliable.
BOHICA21
Baltimore MD
Have run Bio and used Oil and Atf... There are some things that you have to do first..
1 I filter it with a t-shirt into a barrel 45 Gal +10 Gal of ag Dsl. Mix really well
2. Allow to sit for atleast 2 days this will save your filters. "make sure your pump is atleast 3inches from the bottom.
3. I heat the fule to aprox 140 and run it through a good Fule filter to a clean 55 Gal drum or fule tank we use this as a staging area.
As a note heating the fule is great since it will run through your lines a lot easier..
Hope this helps .. Used to run this in an aol 2000 ford 7.3 as will ran like a top...
budman67
Canada (SW ONT)
Yes, that is what I said when there was an LDT powered genset.
It is a large genset though. At 120kw+, that is a LOT of power!
Sorry,it didn't click till you mentioned it,I should have caught that.:cookoo:
120KW,I won't have to worry about using the toaster and kettle at the
same time.[thumbzup] It might be better to have a bit to much than not
enough.Unless this is harder on the GENSET?
budman67
Canada (SW ONT)
Wet stacking,that is from the fella that wanted to idle his deuce
for his inverter,if an engine is running at rpm,it should not wet stack,
right? I was concerned about there being enough load to not
harm the Genset if that would happen?
Hammer
399
Winlock, WA
You should be running at least 50% of the rated load.
So, that would mean running 60kw load!
Too little of a load will wet stack.
Search for it on google, or under our own aux equip forum.
