sewerzuk
- 12
- 18
- Seaside, OR
I actually built this and shot the video several months ago, but I've been to lazy to post it up here.
I had a really nice low hour -003A that I had been using to power tools at remote job sites, backup power for my shop, etc. I was just loading it onto my flatbed trailer as needed, but I decided that it would be fun to build it into an enclosed trailer (which doubles as lockable tool storage). I wanted to make its operation as simple as possible, so my employees could start it without needing a course on MEP operation. My goal was to be able to safely start and run the entire trailer with the push of one button. It came out perfect; here are the details:
I used a TECO PLC and wrote a program to control the generator, a magnetic switch (to isolate the generator's output from the load center), and the air compressor's blowdown valves. The PLC displays messages to the operator about what it is doing (for example, "engine cranking, low oil pressure bypassed," "warming up, please wait,", etc.) The start sequence goes like this:
1. Operator pushes green start button
2. PLC energizes fuel pumps, manifold heaters, and glow plugs for 40 seconds (I found this was the time needed to start the set when it was near zero degrees outside)
3. PLC energizes a relay which bypasses the low oil pressure switch, and cranks the engine (same as holding the start switch in start) for 15 seconds
4. Once running, the PLC disengages the start relay and allows the set to run unloaded for 1 minute
5. The PLC closes the magnetic switch, energizing the load center
6. Once every minute, the PLC opens solenoid valves on the compressor blowdown valves, preventing a buildup of moisture
7. To completely shutdown the system and ready it for the start sequence again, the operator simply pushes the red button
Some cool features:
1. The generator can still be started manually with the control panel switches, in the event the PLC doesn't work properly
2. I have a 110v marine grade power inlet box that keeps 1 circuit live. On this circuit I have battery tenders for the generator's batteries, a heater to keep the trailer above freezing, and a small dehumidifier. This circuit automatically switches over to generator power as soon as the generator is started, ensuring that it is always live
3. I have programmed an auto start feature into the PLC; whenever power is lost to the 110v circuit, it begins the start sequence. I currently have this feature disabled, as I do not have an automatic transfer switch in my shop, so it doesn't help me out much. It may be handy in the future...
4. I added a full power 50A RV style receptacle on the outside of the trailer; this is the same style plug I have on my house generator, and PTO generator for my tractor, so it allows me to plug into my shop or the house. I also have a few spider boxes, and 100' of 6/4 SOOW cable in case a lot of power is needed a long distance from the trailer
5. The air compressor I am running in the trailer is a 3 phase machine, so the genset is set up to run 120/208 3 phase, and I have a 3 phase panel installed in the trailer. The full power outlet receives 120/208 single phase (all of my tools, appliances, etc. run fine on 208v). However, if the full power of the set is needed in single phase (wife wants to dry clothes and cook dinner at the same time), then the genset can be switched to 120/240 single phase. In this condition, the magnetic switch for the load center will still close, but will leave 1 phase "cold" in the load center. All of the single phase loads are still powered, but the air compressor's mag starter is disabled, preventing damage to the motor, breaker trips, etc.
6. The trailer is equipped with LED lighting, so no flashlight necessary for startup
7. I have a cord reel set up near the back of the trailer, supplied by the convenience receptacle on the generator
8. Not shown in the pics and movie is the air system; the compressor is a 3 cylinder, single stage, 25 CFM 3 phase curtis compressor. It has solenoid valves for the moisture separators and tank valves, which blow down every minute. There is an air manifold with an additional moisture separator, regulator, and lubricator (for air tools), and a separate 3 stage dessicant air dryer/filter/regulator.
9. The generator can be run for about 30 minutes at full load with the trailer closed up. It is actually very quiet. Any longer than 30 minutes, and the doors need to be opened to allow for some ventilation. In the future I may add an RV style roof fan to allow the doors to remain closed.
The pics and video were taken a while ago (a few things have changed since then), but it gives you a good idea of the setup.
[media]http://www.youtube.com/watch?v=52dkk7QrmUA[/media]
Some cool features:
