jdeoliveira74
- 3
- 0
- wilmington nc
has anyone used a roof top ac unit on m1009. I was looking for cheaper alternatives to ac from an rv
I had a 67 ford pick up with one similar to it.. My fall back position is bucket seat the darn thing , extend the hoses and reverse mount at the bottom of a center consul type thing...southdave, are you or is anyone else currently running this unit? how well does it cool the truck down?
can you order the kit as is, or do you have to specify a few changes before ordering?
the description says it mounts in the middle and you don't have to modify the existing heating components. but that would place it right in front of the heater vents, blocking them. it doesn't look like there is enough room for both of them under there.
anyone have some pics? this would definetly be the easiest way to go if you don't have to alter the heating system or relocate gauges and switches.
Yes...sort of. There is an M1009 in the yard with the ODI kit installed. The volt gauge was removed to make way for the vent with the controls on it. The B/O switches remain in the stock location leaving only 3 vents. It does cool but it won't freeze you out, at least not in our weather. The Oh-9 that Devilman96 built got a rear A/C as well to compensate for this.Bad news, i called Nostalgia Air today. they informed me that they no longer sell the kits for the CUCVs (stopped selling them just last month!) and they also said the under the dash unit was not big enough to cool the 1009. i think it is made for a pickup cab.
not interested in mounting a RV unit to the top so it looks like i either have to shell out the bucks for the OD Iron kit or piece one together from the salvage yard.
two quesions-
do you have to relocate volt gauge and black out lights with the odiron kit?
what would be the problem with the firewall doing the salvaged route? is it just the hoses going through it?
