1943ht
- 94
- 28
- Batavia, OH 45103
Engine pulled today... and the beast pushed outside so that I could get the steam cleaner fired up and working to clean up the engine compartment... noticed a very interesting issue with the timing chain cover... seems that the engine mount was not lined up correctly when installed at one time or the other .. There is a hole in the timing chain cover from rubbing against the motor mount... this would have resulted in some significant oil leaking...
Of course went and looked at the other engine and its mount and found similar wear marks on the engine mount but not the timing cover instead the rub marks were on the front of the mount where it had been in contact with the back of the crankshaft hub.. Long story short... it appears that both engine mounts have elongated holes where it bolts into the M37 frame... and when the engine is installed, the engine can be moved front to back within the compartment to be centered and aligned with the rear mounts when installed. In both cases, these engines and their past installations did not take this into account and wear marks developed on either side of both motor mounts due to poor positioning. Plan on avoiding that on the rebuild!
