85 M1009 on door weatherstriping
epitts
-1
Terre Haute, Indiana
I found in the TM's that my truck should have them and were on the doors. I took them off to paint the doors. The strips shown in LMC catalog only have them for 73 - 81 blazers. I called to ask if it was an error, they said no. I have been replacing all weather striping on the truck. So were you folks getting your's for the on door strip?
Thanksaua
K9Vic
Fort Worth, TX
The cabs have are the same from 73-91 for the Blazer. (EDIT: Other then the early Blazers with the full removable top)
The Pickups have the same cabs doors as well from 73-87, so it will work.
doghead
4 Star General /Moderator
1,193
Look at the -20P tm.
papercu
33
Baxley, Ga.
If you look at item 2 it says
38-5952 (2) DOOR WEATHERSTRIP-ON CAB BLZ JIM 76-91 (2) 37.44 29.95
To me it way it is mounted, your year model the strip is on the body, the other years it's glued to the door. Wayne
Warthog
245
OKC, OK
From TM 9-2320-289-34P, Figure 171, item #2 GM part number 14016511 and 14016512, it shows the "UOC" of "209". What the heck is " UOC 209"?
Have you ever wondered what the "UOC" number is or what it means? I have.
When you read the -20P or the -34P manuals, do you ever read the first few pages that tell you how to read the manaul? I have.
Let's look at page 4, paragraph 5(a) of TM 9-2320-289-34P
5. Special Information.
a.
USABLE ON CODE. The usable on code appears
in the lower left comer of the Description column
heading. Usable on codes are shown as “UOC: . . . . . . “
in the Description column (justified left) on the first line
following applicable item description/nomenclature.
Uncoded items are applicable to all models.
Identification of the usable on codes used in the RPSTL
are:
Code Used On
194 - M1008,Type “B’’Cargo,Shelter
208 - M1008A1, Type “B” Cargo, Troop Seat
209 - M1009, Type “A” Utility
210 - M1010, Type “C” Ambulance
230 - M1028, Type “E” Shelter Carrier
252 - M1028A1, Type”F” Shelter Carrier w/PTO
254 - M1028A2, Type “F” Shelter Carrier w/PTO
256 - M1028A3, Type “E Shelter Carrier
231 - M1031, Type “D” Chassis
So this tells us that the item #2 door seal is only used on the M1009 Blazer. The door seal #3 is used on all trucks.
I don't remember every seeing on on the Blazers but now I will have to look
So if it has a UOC, it is used on some models. Look it up. No code means it is used on all models.
Carry on.
Warthog out.
Warthog
245
OKC, OK
I did a google search for the GM part numbers. They are showing they are for the 78-82 blazers and suburbans.
They should work.
YMMV
NPD732
Chesapeake VA
I have only seen those seals on blazers. I have no idea why they were added. I had an 84 M1009 and it didnt have them. The 86 I have does. They would work on any of the trucks as the doors and openings are the same.
mikev
73
Culleoka, TN
Same thing for me - none on my 84, but yes on my 86 - both M1009s...
allrevup
Delaware
the INTERNET may not be error and mistake free, but ALL is information...
I think, Johannes Gutenbenber (1398-1468) would agree
Father of the printing revolution and perhaps the most important event in world history to date, by spreading learning to the masses
