Will 12.5 x 20 work on my A3?
jasonjc
289
Gravette Ar.
Work or right. I know they work on the stock A2 wheels but do not fit right. They are smaller than the A3 tires also . There are some good thread's about the 12.50's and the bead on them. They don't have the same bead as a ndt. I'm not sure if the 14.50 has this same bead or not.
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
They will work fine for the rim design. As stated, they will cut your top speed because they are the height of 900s VS. the 14.50 which are the same height as an 1100.
dittle
72
Albia, IA
Don't use the front end (6x6) if you have mismatched tire sizes. Causes binding in the driveline that can/will damage things.
jasonjc
289
Gravette Ar.
That almost just like my truck's, but I'm still using the stock rims up front. It drives a lot better with the 12.50's up front.
spicergear
29
Millerstown, PA
The A3 wheels are designed for tire marked MPT. 14.5R 20 Michelin's are this and another example is the 12.5R 20 Continental MPT's. I have a set of the Conti's on A3 wheels on the front of my crane truck for a better footprint and higher weight capacity over the 900x20 NDT's.
bearboley
Circleville Ohio
I like it that way, I don't think the tire size would be a issue at all with the front axle engaged if you needed it. IE mud or some other smiley surface.
Junkyard Wars Crusher
12B20
Thanks Gerhard. I believe that you and James (M1075) are reponsible for much of the inspiration for it - as a result of various tire/wheel discussions over the years here.
I will be adding this combo to the front of my M342A2 and M108A2 also.
Ah yes, I forgot to add Spicergear to the list of inspiration for the 12.5 tire on A3 wheel list. [thumbzup] Shown in pic here:
I see that patracy's tire website www.militaryoffroadtires.net has some 12.5R20 Continentals that have an upgraded NDT "look". I wonder if I could get him to sell me a couple of those . . .
spicergear
29
Millerstown, PA
JWC, thanks man! The 12.5's are close enough in height to the 900x20's in tandem that there's no concern over bind or height different with front axle pulled in.
12B20
Just wanted to update this thread with a few new pics:
This is the 12.5 R20 Continental tire that I got from www.militaryoffroadtires.net mounted on a M35A3 wheel. (I would be remiss if I did not thank Gimpy, Swbradley, and Patracy for helping make it happen - THANKS fellas ! ! )
This is the above tire and wheel mounted on the front axle with stock 9.00x20 duals on rear.
This is a Michelin xl 12.5 R20 on a canadian MLWV wheel. (wheel from 11Echo (Ron) and Tire from Oldgrunt (Brett) )
