Doghead Mod Failure
ssdvc
639
CT
Had a busted shock on my truck, and I figured while I was at the Hobby Shop on base changing out the shocks, I might as well go ahead and do the Doghead mod. the truck is a 1986 M1009. 67,000 on the odo. She is basically stock and fairly well maintained.
Went to NAPA and got the correct part, SME Line #7-01860-1. Wires werecut properly, ring connectors added and attached to the new relay in the correct locations. Tripled checked everything BEFORE I reconnected all the battery cables (and yes, I removed all four connections).
Anyway, I got everything hooked up, bolted up, tripled checked, Blah, Blah, Blah. Turned the key, had lights come up, glow plugs did thier thing, etc. Waited a few seconds and tried to start her up and..............NOTHJIN ! The lights were all on, but no joy at the starter. Checked to make sure nothing had smoke coming from it (none found).
Re-triple checked all the connections, looked it all over, repeated above process and NOTHIN. Repeated again, this time taking everything apart and doing it all over again. Still nothin ! Man, I was bummed.
Soooooo, I got the old relay out of the trash, removed the ring connectors from the four wires under the dash, fitted spade connectors to them and reused the old relay (no connector, just plugged the wires directly to the relay top). Turned the key and BAM .......she started right up.
I have never heard of the this mod going wrong, so I am thinking one or three things. Either one of the ring connectors was messed up and not making good contact, the relay is bad or I just don't know what the **** I am doing (three could be possible on several different levels).
Anyway, how do I test the relay to see if it is bad?
Thanks.
100acre
Bonners Ferry, Idaho
, SME Line #7-01860-1 ...Is this the correct part for the M1008 too? I still need to do the same but hopefully different results. I hope things work out for you. thanks
R Racing
15
St. Leonard, MD
Try energizing the relay and check continuity between the common and normally open contacts. The doghead mod works so I can't see how u can make a statement witout knowing if u got a crappy relay for sure or not.
ssdvc
639
CT
I don't know what statement you are referring to, but I did the mod, it failed and now I am looking for answers as to why. A "crappy relay" may indeed be the cause of the "failure".
I am asking questions and seeking answers, not making a statement, but thank you for the relay check advice.
rod
Alabama - The Heart of Dixie
I would say that it you checked the wiring to ne in the right locations any you checked the round wire terminals and both of these were OK,, Then it has to be the new relay that is bad.
The part, whether you get it from NAPA, or any other parts place, thay are all the same and made overseas.
I say it is the relay. Just because it is new doesn't mean a thing. Thats why I always check thermostats in boiling water before I put them in.
CROM
Des Moines, IA
The best way to test the relay would be to hook it up and turn the key. Since that didn't work, and the old one still does, you bought a bunk relay. It happens. Return the part for a new one and try again.
This relay mod is worth it. That old one, even though it works, will stick one day and fry your starter.
AceHigh
29
Princeton WV Lake City FL
I did this last week and noticed the new relay was "made in China" but looks just like the one in the picture. It is working great.
I took the original relay apart, it is hard to believe that frail thing worked this long.
doghead
4 Star General /Moderator
1,168
You should have used a meter and tested the setup, after you installed it. I would bet you either made a bad terminal connection or had a bad new relay.
China or USA made, failures in manufacturing do occur and testing every single part before packaging and selling them, is not aways done.
doghead
1,168
To "bench test" the relay,
With the relay "on the bench", you can apply ground to one small terminal, and 12v+ to the other small terminal, and use an ohm meter and see that you get continuity between the two large terminal when the 12v is applied.
Further diagnoses is possible, but I would simply return it and get another new one.
Warthog
227
OKC, OK
I would just file a claim with GL and be done with it. :-D
Seriously, I wouldn't call this a failure. Just an installation issue.
A failure would be that the relay broke and the wiring/starter fried.
deuceaid
Banned
915
149
Yucaipa CA
Ye of little faith...:cool:
I was wondering who was whining about DH, and how that could ever be. Sorry i dont cucv that much to know about the modification. Now my only complain is that DH doesnt have a picture of 1960`s Elvis photoshoped into his wrecked truck avatar:p
acesneights1
21
20
CT
I also did the mod. In fact I had read about it and then my stock relay failed somewhere and I didn't have internet access but it was easy to figure out how to wire it. It works fine and is a must do.
doghead
1,168
Yes, same for either M1008 or M1009.
