Winch Swap from Gasser to Diesel.
shannondeese
19
High Springs Fl
I have a gasser deuce sitting here that has a bunch of problems. But it has a good winch. Can I take the winch and more specifically the PTO off and put it on my Diesel Deuce. The Trans in the gasser is a non-overdrive unit. The one in the Diesel is an overdrive unit. Thanks for any info. Both are M35's.
m16ty
223
Dickson,TN
It should be a direct swap. I'm 99% sure the 3052 (non-overdrive) and the 3053 (overdrive) use the same PTO.
73m819
327
gainesville, ga.
the only thing you need to do is grind the bell housing to clear the gasser winch driveshaft
73m819
327
gainesville, ga.
Look up BFRs crane truck build, he put a gasser winch on his a2
gringeltaube
Staff Member
2,682
Montevideo/Uruguay
.......... Can I take the winch and more specifically the PTO off and put it on my Diesel Deuce. The Trans in the gasser is a non-overdrive unit. The one in the Diesel is an overdrive unit. Thanks for any info. Both are M35's.
Don't know if YOU can.... but why not give it a try! :razz:
Yes, the PTO itself; the shifter & bracket; linkage, etc; all is exactly the same for both.
G.
