CanadianAR
- 87
- 18
- Ontario, Canada
I only recently got my hmmwv, and while doing fluids and such across the board I found my transfer case quite low on fluid. I used what we had on hand at work. It’s called MD3. It’s an ATF meant for older vehicles calling for Dex 2/3 and the older Merc.
Should this be ok or should I source something labelled Dex 3 on the front? Personally I think it’s fine, but some guys know more hmmwv quirks then I do,
thank you ,
thank you ,
