Polaris MRZR-D4
Q Dude
Georgia
My bad. As soon as I hit the send button I realized you probably had already done that. I bought the black one and had it painted.
I just took a panel to my auto guy and he color matched it. I looked into all the CARC stuff....decided to just color match it.
Where did you get your Half windshield from May I ask? I have a 2017 Diesel MRZR Will that same windshield fit mine? Thanks 👍🫡
DaveSC
14
West Virginia
When I bought mine at the USMC logistics base in GA, the dufess said CARC stood for Carcinogen. Looked up CARC when I got back and it means radar absorbing paint.
Bsuit
Tennessee
My 2017 MRZR-D4 is overheating. It has a new fan, relays and fuses. When the machine reaches 180 degrees the fan begins to jerk and will then make a few rotations and stop again. It will then do the same sequence of jerking, stopping, spinning a few times and then stopping. Any help is appreciated.
nickd
52
Newport, Delaware
i Have a gas powered MRZR, The gas models have a temperature sensor on the block. Since you changed everything else, I would look around the motor for the temperature sensor since you mentioned changing everything else that would be involved with the cooling system
Bsuit
Tennessee
Ended up being a bad alternator not putting out enough volts to turn the fan and clogged radiator fins. Thanks for the help though.
