Current status is : the 00 gear lube came. I will be changing the steering 80-90 weight to the 00
Also be greasing the fittings. Have to look at manual : looks like grease fitting or brake fluid bleeder inside the wheels facing up. Front wheels. Sorta think I maybe it’s a grease fitting to put grease in the boot.
The schedule when the brakes will be done is not set yet.
Until then I will be running the engine every 10- th14 days for round 30-35 minutes.
Just gotta ease her outta the garage then back her back in when done.
Thank You.
Thank You.
