MEP-804A Low Voltage - Voltage Regulator Question
LuckeyD
342
Vilseck, Germany
Hey! You are correct. It was late. 005563350 or 005565306 for the Libby. 10 K Ohms. The Kits 013630493 and 015006070 for the Libby. Mr PEAPVP is correct. Recommend being careful on that cage code. The vendor changed many times over the life of the gen. The last ones were just a carbon board and a wiper so current normally was not an issue I suppose the engineers thought. Last ones I got was at a store in Be' er Sheva Israel while on a mission.
LuckeyD
342
Vilseck, Germany
Oh the one check was ro measure thru the voltage adjust R1. That puppy is a 10K Ohm POT so you should read around 13K OHMs on that one. Hope the rest helps. If the fuse is OK, it is probably the regulator or a wire issue. The checks will show what is what.
RonK
Vermont
The fuse is good and the pot / VR measure 13.5K CW 3K CCW
RonK
Vermont
I was doing the VR tests in the PDF that LuckeyD posted above and things were not looking swell.
I decided on a hunch to just pull out the VR so I dug into my junk, found some wire number labels and took it out.
I removed the board and this is what I found:
My 40ish years of experience in the electronics industry tells me that this VR has seen better days.
Where do I get a new one?
I found this one: https://greenmountaingenerators.com...1-363-0493-6110-01-384-7192-6110-01-363-0494/
Anyone have any experience with aftermarket VR's?
Thanks for all of the help!
Ron
2Pbfeet
1,485
Mt. Hamilton, CA
Ron
From the armchair here, that VR doesn't look that bad, but I guess it depends on one's tolerance for repairs. The newer voltage regulators do have a number of advantages.
All the best, 2PbFeet
RonK
Vermont
From the armchair here, that VR doesn't look that bad, but Iguess it depends on one's tolerance for repairs. The newer voltage regulators do have a number of advantages.
I agree. No burnt traces so the board is good but absent a schematic it is just more efficient to replace it. Maybe I will repair it as a spare.
Summerpaws
197
33
Hampton, NH
Ron
Ron, aren't these guys the best? Reading your thread, it looks like everyone involved are old farts. Even you and me. Think of the years experience being tapped. Glad you found the issue. Looks repairable to me if you either can't find a replacement or have a stroke from the price. All you need to do is find the tech specs or someone who knows the value of the resistors.
RonK
Vermont
I definitely appreciate all of the help.
There are at least 2 diodes and one of the TO-220 FETs damaged in this one. Strangely one leg of the FET was
broken. I haven't disassembled it far enough figure out if it burned out of the body of the FET or if perhaps
it was a failure due to long time vibration.
I needed to get the generator back in service so I bought one from Kurt. I can see from the pic that it seems
to be well thought out with both input and output fuses.
I would love to find a schematic for the Libby regulator so I can try to repair it as a spare.
RonK
Vermont
Update:
I bought a VR from kloppk. Installation was easy. The multiple variants thing did crop up but after exchanging a few
emails (he responds very quickly) the problem was solved and the generator is working.
I removed the external large fuse because it is redundant with the fuses on his VR.
Tip: Remove the top cover for better access to the controls compartment. The time to remove
the bolts is well worth the trouble.
If you need a new VR buy it from Kurt. His design with input and output fuses is superior to the original and
his customer service is exemplary. Thanks Kurt
