Page 1 of 69 1 2 3 4 5 11 51 ... LastLast
Results 1 to 10 of 686
Thread: Operation "URGENT RESTORATION"
  1. #1
    4 Star General m38inmaine's Avatar
    Join Date
    Nov 2006
    Maine USA
    Posts
    2,095
    Thanks
    680
    Default Operation "URGENT RESTORATION"
    This will be the official restoration thread of the newly acquired M561 I posted about in an earlier thread. I was going to get it on the way to the Weare, NH rally but I just could not wait. I headed out Thursday at midnight and arrived in NY at 07:30 Friday Morning. Took about 6 hours of messing around, extracting parts from multiple hidey holes and loading. Got a few bonus items such as a hard top and NOS tailgate which were un expected but much appreciated. Arrived home just after midnight Friday/Saturday morning.
    As you can see the trailer is loaded to the max, I don't think I could have fit much more, both carriers and the pickup bed are full of parts. It's going to take a couple days of sorting through things to see what I have for extras to trade. I do have some extra cab top bows, not sure if they are all complete, a really nice set of folding troop seats and an extra rear steer box cover for Tom.
    My priority parts list will be a front steering box and front fenders. I got a nice set of rear fenders and splash guards but no front fenders. The window glass was all smashed out so a new windshield assy. may be in order. My next challenge is to get it all unloaded, headed out now.
    Oh, and you are probably wondering why is the back half of a tractor is hacked off and attached to a carrier with a steering wheel. That was a farmer who had an idea to use it to harvest apples out of his orchard. He never finished it and I'm not sure how he planned to power it or get the steering linkage to work. However, it is a nice carrier and provides an extra rear tractor diff and two extra tires.
    Keep a look out for part numbers, socket sizes etc. as I progress along. I will do my best to list all the cross over part numbers I can find. Perhaps at the end we can come up with a collective list of part numbers.
    Attached Images Attached Images
    SSG USA(RET)
    85-05
    12B Combat Engineer
  2. The Following 3 Users Say Thank You to m38inmaine For This Useful Post:
    jeffhuey1n (07-30-2019), M813rc (06-30-2015), USAFSS-ColdWarrior (07-08-2016)
  3. #2
    4 Star General combat32's Avatar
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    Thanks
    40
    Default
    A mountain of goat treasure! Good luck we are all pulling for ya. If I have any stuff you need let me know.
    Tom
  4. #3
    4 Star General AMGeneral's Avatar
    Join Date
    Mar 2006
    Morganton,NC
    MVPA
    11514
    Posts
    2,272
    Thanks
    379
    Default
    If you're still looking for a Goat windshield,you may try member popacom here on SS.
    I tried replying to your PM,but your PM box is full.
  5. #4
    Join Date
    Nov 2006
    Maine USA
    Posts
    2,095
    Thanks
    680
    Default
    Thanks, I will give him a shout. PM is empty now.
    SSG USA(RET)
    85-05
    12B Combat Engineer
  6. #5
    Corporal
    Join Date
    Jun 2015
    Greenville/NH
    Posts
    26
    Thanks
    Default
    Wow that's a whole lot of history on that there trailer! Awesome project, I can't wait to see it progress and hit the road...
  7. #6
    Join Date
    Nov 2006
    Maine USA
    Posts
    2,095
    Thanks
    680
    Default
    If all you goat owners felt a disturbance in the force yesterday it was my fault. The carrier on the end of the trailer would not roll, the wheels would rotate a few inches then lock up. I unhooked the drive shaft and still locked, the differential was locked and either while under power or dragged the result was the axle shafts snapped a u joint on each side. The steering was also locked solid and the wheels of course were not straight. So I had no choice but to get the torch out and cut off the axle shafts and both steering tie rod tubes. I don't have a tractor to unload with so I had to have them all roll off. That carrier will be used for parts. The other units rolled off fine. I was able to use a bar and manually rotate the steering coupler on the other carrier, it actually turned quite easy, what a relief.
    I did manage to get some work done, removed what was left of the fenders on the RH side and removed all the bolts holding the cowl on. Started to disconnect all the wiring on the dash and removing switches etc. Pictures of the removed parts and Tom's deck cover, that carrier is supplying parts already.
    SSG USA(RET)
    85-05
    12B Combat Engineer
  8. #7
    Join Date
    Nov 2006
    Maine USA
    Posts
    2,095
    Thanks
    680
    Default
    Had a little time after work today to get some work done on the goat. Managed to get the cowl off, had to cut it in several pieces and carefully remove the wiring. Looks naked but much better. Next I will remove the seats and clean the cab.
    SSG USA(RET)
    85-05
    12B Combat Engineer
  9. #8
    4 Star General mkcoen's Avatar
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,541
    Thanks
    967
    Default
    PM sent regarding steering box.
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
    US ARMY - Overlanding since 1775
  10. #9
    4 Star General dmetalmiki's Avatar
    Join Date
    Aug 2006
    London England
    Posts
    4,594
    Thanks
    599
    Default
    I am totally taken aback by your enthusiasm to do this project. Well done you! I shall be following your progress at all stages of the project. Awesome.
    DIAMOND T M20.
    M54A2 I.H. M62. wrecker
    M54A2 5 Ton (with Praga command station surveillance body fitted)
    M45 530C TFFT fire truck
    1942 Ford Jeep (with underfloor tulsa winch)
    1945 Willys Jeep (with V8 flathead Engine) And overdrive.
    Packard Staff car. (WW11. General Pattern Tribute).
    Ural Military Motorcycle.
    Ex Army Hyster 4 ton Fork lift.
    Onan 7.5 kw ex army generator.
  11. #10
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    Thanks
    40
    Default
    Quote Originally Posted by m38inmaine View Post
    Are those wiper motors still good to go? Tin snips look like they came in handy.
    Tom
Similar Threads
  1. New restoration project M100 "Tubby" 9.6.14
    By swiss in forum Trailers
    Last Post: 10-31-2016, 20:54
  2. Thinking about redoing an older "restoration" of mine...
    By linx310 in forum M38, M38A1 and M170
    Last Post: 12-24-2011, 21:47
  3. Replies: 15
    Last Post: 10-20-2010, 06:53
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
