- 1,811
- 1,510
- 113
- Orlando, FL
Any more info on what this is called? I tried searching, but having the right words always helps.There is also a meritor setup guide online someplace for re assembly.
Why were you unhappy?Just saw this thread and thought I'd share my M37 w/Detroit experience. I'm sure Detroit makes decent products. The one for the M37 just might not be one of them. I tried, twice, to run one. Finally gave up on them, went back to open, and have been happy enough with it that way to never look elsewhere.
I don't have many miles on mine, but they have all been hard. From putting 9000lb of gravel in the truck, to pulling a ton of logs out of the muddy woods where the locker was the only reason i could get into the location. Each load of logs was at least 6000lbs. I have had zero issues so far.Has anyone with an LMTV/MTV had a locker fail or any other part break yet that could be caused by the locker?
Sent from my iPad using Tapatalk
What are you referring to?They are also not on an LMTV...
Sgt Jiggins failure wasn't on an LMTV... He mentioned axles from '51....What are you referring to?
Which truck has the locker? Looked at your signature and you have too many options. That must be awful .Yesterday I dragged a 20ft container in red clay mud. The container weighed appx 10K. Only reason I could get the truck there and move it was the locker combined with "mode". Absolute animal in less than stellar conditions. It does announce itself to me sometimes on turns if I'm under power, but other than that I don't know its there until I need it, then I KNOW!
Sorry the LMTV as that’s what this particular thread was about.Which truck has the locker? Looked at your signature and you have too many options. That must be awful .
Great. Do you have a link?Wehring has one on his build thread..... but it is from the cab.
Edit, my memory worked..... next post has the link.Great. Do you have a link?
