Page 8 of 8 FirstFirst ... 4 5 6 7 8
Results 71 to 72 of 72
Thread: Are hydraulic winches hard to come by?
  1. #71
    4 Star General coachgeo's Avatar
    Join Date
    Nov 2010
    North of Cincy OH
    Posts
    2,613
    Thanks
    984
    Default
    Quote Originally Posted by Hard Head View Post
    I will remove the front bumper, make a frame extension to mount one vertical on my 5 ton and see how it behaves. I would hope that the cable tensioner would eliminate or reduce bunching. I should have done this before I started asking about where to mount it.
    Did you ever do this?
    One does not get troubles in life... just character building opportunities. Build on with a smile
    Moderator: Orange Tractor Talks & AmbulanceRV
    Daily driver- 99 VW TDI or 2002 KLR DIESEL w/cvt... weather permitting
    Projects: 96 M1078, 97 Triumph Tiger w/3cyl Diesel Kubota
    Sold: 1962 Dieselized Unimog 404, 1984 Int. 24foot Flatbed, 97 Jeep TJ heavily Modified, Datsun Roadster(s) & 510(s)
  2. #72
    General Hard Head's Avatar
    Join Date
    Nov 2013
    Greenville SC
    Posts
    531
    Thanks
    80
    Default
    I never got around to buying or finding someone with a truck to work with me. Just knowing what I do know about these winches a feet forward mount is the best. I have had customers break the winch casting by not having equal pressure on the mounting bolts thus cracking the casting. I have thought about mounting the winch under the frame and using the guts from 2 snatch blocks to direct the cables to the front or rear of the truck. If anyone with a truck near Greenville SC wants me to work on this just let me know. I am pretty sure I can fabricate just about anything that can direct the cables.
    When you put the 2 words 'The' and 'IRS' together it spells 'Theirs....'
  3. The Following User Says Thank You to Hard Head For This Useful Post:
    coachgeo (09-21-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
