MEP 802A Fix-up Thread
CallMeColt
1,327
Wilson County, Texas
I ended up getting a second trailer mounted MEP-802A but it had a seized motor, so it will be parted out.
I expected it to be no good, as it was already missing a lot of parts, but it was cheap enough. After taking it down, I found that it could have been saved, but I didn't want to spend the time with it. The money I spent on it was worth it for the trailer, and I should be able to recover some money selling parts on my eBay store. I get some spares myself as well. Will be keeping and eye out for another one.
CallMeColt
1,327
PMCS prevents failures in the field!
Was looking things over today and noticed that the fuel shut off bolt, nut, or whatever you want to call it, was only in by two threads and about to strip out!
This would have caused quite the issue if it messed up while I was out at my off grid place. Not that it could have been the end of the world, but, the unit would have not shut down right away. Not to mention, could have really stripped out and messed up the hole bad.
Turned it the half turn out and got a 10-32 tap and cleaned up the threads. Used some high temp thread locker from my gun bench and threaded it back in.. went in nice & smooth. Snugged it up. Should be good now.
Glad I caught that before it was worse!
wheelspinner
1,511
North Carolina - FINALLY !
I have 802 motors
CallMeColt
1,327
Generator is still running good & strong! :giggle:
Just wanted to share in this thread something I posted on my YouTube channel that has to do with the MEP 802A & 803A;
I know it's not directly related to this unit but I have kept up for many years with this thread & everything I have learned about these generators here, so I figured it was fitting. Shared it on my other threads as well. Not trying to SPAM.
jmenende
364
Puerto Rico
Hey guys. I tore down an 803a lpw engine that had some issues and cant find a part number in the manual for this bushing/sleeve. Need to replace a few and the only number on the part is 3520. Anyone have these?
loosegravel
Just a retired mechanic who's having fun!
504
887
Enumclaw, Washington
If that's a cam bushing, I found part #751-10950 listed on page 20 & 21 of the Lister Petter master parts manual. It's listed as "gear end" but I see no other part number for the remaining (3) cam bushings.
Sgt Jiggins
Potato Peeler
204
Lynchburg, VA
I haven't (yet) removed the covers to peer inside (this time), but I've got a fuel leak on the end of the fuel tank. I've already replaced the well nut with a nice viton unit. What else down that way might be leaking? The return? I think it's related to running, not sitting.
CallMeColt
1,327
The cover is easy to take off. Remove it & run it. But if you replaced that lower well nut with the original type one, it's possible it failed already. They can't be more than a little past hand tight, & if they rotate at all in the hole the seem to leak. But none the less, removing the cover to look will more than likely answer your question on it's own.
