Fuel tank sending unit assembly
dodjh
14
Central, MS.
You know the rules of the internet. You have to post pictures or it didn't happen...lol!
Sounds like you're on the path to getting it back on the road.
I'm getting there...took several pictures but haven't figured out how to post them.
Had some help on the weekend removing all my drill pipe, 4X4's, 2X4's, 2X6's (last two were blocks) used to lift and slide my bed back and a Pipe saw Horse the bumper rested on.
Bed is sitting on the frame except (3) 2X4 blocks up front on both sides to leave room to finish hooking up the RPV (rollover protection valve)
Does anything connect to the part of the valve that sticks through the bracket? The side ports go to the Tank and Vent, I marked them and they're labeled
on the valve body but don't remember where the one going through the bracket goes.
dodjh
14
Central, MS.
No good and worn out. Have to keep an eye on fuel w/ paint stick stirrer. Primitive but only run out of fuel 90% of the time.
deathrowdave
76
falmouth, ky
I have added the resistor from another sender to the needed sender many times . Building Hot Rods . It’s rather easy , just have to match sender and gauge ohms to read correctly . As is try to locate a sender for 37 Chevrolet to use 2 5/8 gauges from a C70 , really was a super easy fix . PM me , I’ll send email address , maybe we can get you fixed up easier than finding a new sender .
