Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: Smoking on start up (electrical)
  1. #21
    Sergeant Major Curtisje's Avatar
    Join Date
    Jun 2018
    Twentynine Palms, CA
    Posts
    124
    50
    Default
    Quote Originally Posted by pgp29646 View Post
    Thanks for all the advice- got her back up and running!!
    What fixed it in the end?
    James Curtis
    1984 M1008 CUCV Pick-up
    1985 M1028A3 Wrecker, Holmes 440
    M101A3 Utility Trailer
    M116 Generator Trailer
  2. #22
    4 Star General MarcusOReallyus's Avatar
    Join Date
    Jul 2012
    Virginia
    Posts
    3,936
    1,150
    Default
    Quote Originally Posted by rspring View Post
    Do I need a 24V solenoid? Thanks
    Nope. Just use the one mentioned in the Doghead sticky. You can find the sticky listed in the "Helpful Threads" section (see the top of the forum) and in the Wiki.
    Non standard parts in CUCV?
    You offend against the pure OEM design!
    Evaluate self! Reflect and repent!
    Or... maybe not.
    M1028, M101A2
  3. #23
    Private
    Join Date
    Oct 2016
    Sioux Falls, SD
    Posts
    Default
    It turned out to be a fried starter solenoid and an issue with the spindle of the starter (was missing a bearing or something and the shaft was loose). Ordered a new starter from a shop that rebuilds them and it fires right up. Turns out the shop owner was a mechanic in the Army and knew a lot about the system. His warning to me was to never wear a ring or watch when working on a 24v system. ”Could fry off a finger” if contact was made! You might be able to replace the solenoid only. Easy fix really, just took time to figure out the issue. Folks on this thread were very helpful!
    Good luck
  4. The Following 3 Users Say Thank You to pgp29646 For This Useful Post:
    Curtisje (11-04-2019), firefox (11-05-2019), MarcusOReallyus (11-04-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
