Results 1 to 6 of 6
Thread: Head lights not working
  1. #1
    Sergeant Major bmH1065's Avatar
    Join Date
    Jul 2008
    Iola, Kansas
    Posts
    106
    Thanks
    Default Head lights not working
    Found last night my head lights don't work. Where should I start? Thanks
  2. #2
    Colonel tiger422's Avatar
    Join Date
    Jun 2008
    Lakeland/Florida
    Posts
    324
    Thanks
    39
    Default
    light switch
  3. #3
    4 Star General BLK HMMWV's Avatar
    Join Date
    Apr 2009
    Pasadena California
    Posts
    1,191
    Thanks
    247
    Default
    What kind of light switch do you have?
    3 lever, electronic touch pad ?
    Things to check.
    Bad bulbs
    Loose ground.
    Loose connection on back of switch.
    High beam switch.
  4. #4
    3 Star General roscoe's Avatar
    Join Date
    Jan 2009
    Spencerville, Indiana
    Posts
    998
    Thanks
    173
    Default
    I'd check bulbs then switch.
  5. #5
    4 Star General jasonjc's Avatar
    Join Date
    Apr 2005
    Gravette Ar.
    Posts
    5,171
    Thanks
    1,131
    Default
    Make shure the switch is set right.
  6. #6
    Colonel tmbrwolf's Avatar
    Join Date
    Apr 2008
    Manhattan, Kansas
    Posts
    209
    Thanks
    Default
    I'd check the light switch first, make sure the dashlight lever isn't in the "park" position, you can tell easily if the front marker lights are on then it's in "park"!
Similar Threads
  1. Most of my lights are out. Duh?
    By Mark3395 in forum CUCV
    Last Post: 03-02-2009, 15:24
  2. Tail Lights Not Working
    By Maxgussam in forum The Deuce
    Last Post: 02-20-2009, 23:12
  3. Replies: 8
    Last Post: 07-04-2008, 21:25
  4. Halogen Head Lights
    By Loose Deuce in forum The Deuce
    Last Post: 02-23-2005, 21:04
  5. Head Lights
    By M82A1710M in forum The Deuce
    Last Post: 10-24-2004, 17:18
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
