Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 35
Thread: 12v winch on 24v
  1. #21
    General
    Join Date
    Dec 2010
    Polk County, Florida
    Posts
    479
    251
    Default
    Interesting. Thanks for that link.
    According to the spec sheet it does look like (at least for the 20k unit) that it is capable of running on 12 or 24v.
    I have never heard of this company. Of course that does not mean they are not any good but I would be at least cautious until I found out more about them.
    I did note that they offer 5 winches, from 13k to 20k and they call them all "Truck winch" except for the 20k which they call "Car winch". That seems odd. Also, the roller fairlead on the "Truck winches" looks much like the ones used by Warn and most of the other makers we are more familiar with here in the US. The 20k "Car winch" is completely different and to be honest looks pretty lame, especially the side rollers.
    Still, an interesting option to consider... Especially if your not planning on needing 100% or more of the capacity of the unit. (Like pulling cars up onto a flat bed trailer as opposed to pulling a stuck 5 ton MV out of fender deep muck - by yourself in the rain at 0300 in 35 degree temperature.)
  2. #22
    Moderator m16ty's Avatar
    Join Date
    Mar 2007
    Dickson,TN
    Posts
    9,556
    987
    Default
    Thanks for all the input.
    After hearing the responses here and doing more research, I'm leaning toward just a 12v winch powered by a 12v deep cycle battery. I was worried I'd run out of juice in the middle of a winching operation but after hearing people here it looks like I'll be ok.
    The winch is kind of on the back burner at the moment. Too cold and messy right now.
    The only member that ever gave himself a infraction point.
    www.americanmachinerymoversinc.com
    1972 M35A2C dump w/w (nothing more than a hunk of scrap iron between two winches)
    1985 Mack RD822SX (Operation Desert Storm veteran)
    M1000 transporter
    1967 M715
    M101A2
    4- M105s
    M149A2 tanker trailer
    M49 parts truck
    M35A2 parts truck
    M936 (converted to lime spreader truck)
  3. #23
    Join Date
    Mar 2007
    Dickson,TN
    Posts
    9,556
    987
    Default
    I went out and bought a 8,000lb 12v winch last week from Harbor Freight. I winched a deuce upon the trailer with nothing but a battery and it handled it with ease. Looks like this setup is going to work fine.
    M1000 transporter
    1967 M715
    M101A2
    4- M105s
    M49 parts truck
    M35A2 parts truck
  4. The Following User Says Thank You to m16ty For This Useful Post:
    Heath_h49008 (02-09-2012)
  5. #24
    Colonel Adrian A's Avatar
    Join Date
    Sep 2012
    Fresno Ca.
    Posts
    261
    Default
    I know this is old. It has some good info though. I'm considering a 15000 lb. 12 volt winch with a separate deep cycle battery charged by a 12 v wire from my solar charging system. It has 12 and 24 volt outputs in a fuse box.
  6. #25
    dumpsterlandingfromorbit! gimpyrobb's Avatar
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,631
    2,443
    Default
    Quote Originally Posted by Adrian A View Post
    If you are talking about the solargiser system with the grey box that has fuses(and circuit breakers) in it, that is a bad idea.
  7. #26
    Join Date
    Sep 2012
    Fresno Ca.
    Posts
    261
    Default
    Why is that?
  8. #27
    Join Date
    Sep 2012
    Fresno Ca.
    Posts
    261
    Default
    Never mind. Your right the current draw through the solar giver would trip the breaker when used.
  9. #28
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,631
    2,443
    Default
    That, AND the fact you will be pulling 12v from a 24v system, you will destroy the batterys the first time you use it.
    If you want to use a 12v on a 24v system:
    A, wire it to 24v
    B, get a dedicated 12v system
    C, a balancer(I forget the correct name right now, but will find it for you) might work, but I doubt it.
    EQUALIZER! Yeah, it takes the 24v from the alt and charges each 12v battery individually. That way, you don't under charge one batt or over charge the other.
  10. #29
    Join Date
    Sep 2012
    Fresno Ca.
    Posts
    261
    Default
    I would be happy to find a 24 volt winch that I could afford. If not maybe a 12 volt winch with a separate battery.
  11. #30
    4 Star General
    Join Date
    Dec 2006
    Greenback, TN
    Posts
    1,323
    1,565
    Default
    I've seen 12v winches used on 24 v Unimogs a number of times. It's really quite simple and works great if you plan a separate 12v battery. Mount it close to the winch if you can, an advantage normal winch installations rarely have. The limitation is the AH rating of the battery versus drain of the winch. No 24 to 12 system I have heard of, even the battery equalizers (Vanner is good brand) handle anywhere near winch current. I have a 50 amp Vanner on a 404 Unimog that runs a snow plow, and that works fine (but sure as heck is not the load of a winch).
    Charge the 12v battery through a 24 to 12 converter made for that purpose. USA companies like Wilmore have been making such converters for decades for use on professional installations such as airport fire trucks, heavy equipment, etc. The converter takes 24v from your vehicle and manages the 12v battery charging, limited to the current the model was designed for. Your 24v truck system is not modified at all.
    I have in use (for 10 years now) a Wilmore model 1416-35 that was old when I got it. It came off an airport fire truck. Also in use here: a 1416-15 (15 amp) and a newer 1640-12-15. Many of their newer converters have an enable line that can come from a switched source to turn off the converter when the vehicle is not running, a good idea.
    NewMar makes some good professional devices too. None of these devices are cheap, unless you buy cheap third world stuff like Samlex. I started out with Samlex and fried several. Never again. I want to install and forget.
    You can run radios, cell chargers, GPS, anything, off the separate 12v battery.
    Bob
    1952 M-38
    LST-178 Lube and Service Trailer
    M-1082 LMTV Trailer
    2 x M-105 trailer, bare
    M-105A2 with sides, bows
    'old' Onan 115 v radar power generator, 4 cyl boxer engine
    2 x S-250 Shelter, 318 shelter
    1957 Unimog 404 flatbed, French NATO (Germany)
    1965 Unimog 404 radio truck (German Army)
    1967 Unimog 404 flatbed project truck
    3 x Unimog 406's
    1988 Unimog U-1300L with 10' NCO Alaskan Camper
    1968 Haflinger bug-eye US version but pre-Pathfinder.
    1994 M-1078 LMTV with 10' NCO Alaskan Camper
    1995 M-1078 LMTV
Similar Threads
  1. Diablo Build Update (pics)
    By devilman96 in forum Deuce Modification and Hot-Rodding
    Last Post: 09-15-2013, 23:33
  2. Adding A/C to a M35A2
    By sldinc in forum Deuce Modification and Hot-Rodding
    Last Post: 12-27-2010, 21:40
  3. Need help- 12v EGT guage in 24v truck
    By fabiodriven in forum The Deuce
    Last Post: 05-17-2009, 19:20
  4. Converting a 12v starter to 24v
    By 81K30DRW in forum CUCV
    Last Post: 02-20-2009, 21:41
  5. 24v & 12v questions.
    By BKinzey in forum CUCV
    Last Post: 05-14-2007, 10:08
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
