24v to 12v converter?
Bravojmc
Palisade, Colorado
Does anyone know a cheaper way to get a 12v source on my Hmmwv? I do not have a dual alternator... I see the small 24v to 12v boxes on epay but don't know if it will work.. all I'm going to be running on 12v is a [h=1]Pro-Gard G5000UTX-V electronic long gun mount... anyone have any ideas? IMG_7600.jpg[/h]
shawnshumvee
Janesville WI
Hi. I also was hoping there was a way i could cheat and get 12 volts from the Humvee, some how-some way? But no luck. I believe there isn't any tricks, so i decided to get a cheap small black plye converter and hook it up. Well, it works perfect and I'm running a small Radio, Small cobra CB, small light bar (like the H1 hummer has, you know, the small 3 amber one above the windshield) and an USB port. and everything seems fine. So currently that's the only option i know. In my opinion the 24 volt system stinks. It makes customizing more difficult and expensive, but thats my opinion.
good luck.
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
good luck.
Your other options are a battery equalizer or a dc-dc converter. I have a Newmar 32-12-35a (dc-dc conterter) that will convert 24v to 12v and if I choose, it has an option to maintain a 12v battery.
http://www.newmarpower.com/wp-content/uploads/2016/01/Manual-DC-Converter-Std.pdf
gimpyrobb
27,787
779
Cincy Ohio
Just so its been stated, I believe the battery equalizer to be a better option(thats what I am currently using. 21100E00-100A I believe).
infidel got me
33
Newberry, Florida
Bravojmc- I have installed 2 of the waterproof convertors in my battery compartment(two separate trucks). I'm running just a cell charger right now, but plan on a am/fm radio, cb, light bar and a dome light. No issues so far.. Purchased on e-prey for under $15, with free shipping. Sellers name is wenhaisi 6. ( I'm not affiliated with e- bay seller)
LouWon
103
Michigan
If youre not going to be pulling a ton of current, then you can take power from the second battery, you will have 12 Volts, that is what I do for the CB and cell phone charger , no problems
Check it out with a voltmeter, first battery is at 24V, second is 12V and the same goes for charging, it drops to half on the second battery+
gimpyrobb
27,787
779
Cincy Ohio
Do not follow this advice, it will ruin your batteries!
LouWon
103
Michigan
Without starting a life long debate, I have to ask why it would ruin the batteries
I have been running this setup and have no issues with my batteries
If I would be running a winch or something like that, I could understand.
But for a momentary switch, such as the one to release an rifle or 12V supply for a CB or cell Phone charger, I don't see an issue
Is there a reasoning that it would ruin the batteries ?
papakb
1,196
San Jose, Ca
If you don't understand electrical power then tapping off of the low side battery is a disaster waiting to happen. It's even worse if you tap across the high side battery. Everything should reference to the vehicle ground but simply tapping off of the low side battery draws power from that battery first creating an imbalance in the system which is a no no. There are plenty of inexpensive 24v to 12v converters (regulators, voltage droppers) out there from China and most of them will work OK for relatively low current loads such as small AM/FM radios or basic CBs or music players but when you start to draw serious currents like higher power radios do your asking for trouble. In that case you really want a battery management system like those made by Vanner. They take in the 24 volt power and balance the draw equally so that you have safe, solid 12 volt power and they have units that will handle up to 100 amps. The Vanner units can be expensive because they're made for commercial systems but you can find them online for reasonable prices.
Kurt
KG6KMJ
donquijote
36
Louisiana
Papakb... what is the max safe amp load you recommend on a cheap inverter before moving to better commercial grade?
Sent from my SM-N915P using Tapatalk
gimpyrobb
27,787
779
Cincy Ohio
I would stay an amp or two below its rated output. If you are using delicate electronics with the converter, it might be time to look at "good" ones.
TOBASH
3,932
Brooklyn, NY
Does anyone know a cheaper way to get a 12v source on my Hmmwv? I do not have a dual alternator... I see the small 24v to 12v boxes on epay but don't know if it will work.. all I'm going to be running on 12v is a Pro-Gard G5000UTX-V electronic long gun mount... anyone have any ideas? View attachment 680375
First, before you make this decision, you need to tell us how much amperage you are going to require. You need to tell us what type of equipment you will be running. If you are just going to charge a cellphone, a simple 2Amp converter that plugs into a lighter is available. If you are going to run a 2000 Watt stereo system, then you need entirely different technology.
If you are considering running a 12V winch, then you do not need to make any changes because a 12V winch will operate on a 24V circuit.
My suggestion is first decide how much amperage you're going to need. Then multiply that number by 2. The final number will dictate what type of converter you require.
T
Bravojmc
Palisade, Colorado
T
I listed what I'm wanting to install on my rig in the first thread. Only thing I want to run on 12v is the momentary switch... I have a external backup battery to charge my cell if need be and the winch will be 24v
Craig2121
NH
i just got a pulse tech distribution panel circuit breaker, off "Eb@@".....cheap....seems well built an rugged but havent installed yet, been raining for 2 weeks now.....i read a thread in here someplace about someone having one....hahaha, sorry thats all i remember bout thread....plan on just running the usual electronics.....its got 8 24's....4 12's in it.
gimpyrobb
27,787
779
Cincy Ohio
I've helped a member here install one of those, they are very nice, but not a dc-dc converter. I recommend using a 24-12v dc converter to hook up the 12v side(or a battery equalizer).
