002 flywheel position for IP install
Silverbulletsmith
N. Georgia
I've read hours and hours on here about these gennys, and I know I've seen where it's been discussed but I can't find it again.
As I recall, you insert an 1/8" rod in the little port on the side of the IP, position the flywheel to a mark, and bolt it on.
Could someone please give me a pointer?
Thanks in advance!
Grant
Silverbulletsmith
N. Georgia
Jerry,
I've got the blower cover removed, so I can use either the blower or the flywheel (between engine and genny).
Just need correct engine position relative to IP with 1/8" rod installed.
storeman
52
Mathews County, VA
Silver bullet,
You need to go to the TM and read the timing section. The index you use is the pointer over an open hole just below and to the left of the IP. It lines up with PC marks on the flywheel (versus fan). Rotate carefully until lined up with PC center mark then install IP. Go only in direction fan blades dig in (can't remember clockwise or counter) someone will chime in and clarify. If you go past marks, keep going, don't reverse or you pickup system slack.
Jerry :beer:
