12-Bolt Beadlock questions
92
Navasota, TX
I didn't balance mine and it drives ok. I'm running Dually front wheels with 37s and my m1102 take offs until I can get my wrecker bed installed and then it'll have all Dually wheels on the rear with 37s. None of them are balanced. I drive it 35 miles one way to work when I don't want to unhook my gooseneck from my Sunday truck.
Brett
1StumpJumper
NW Washington
FWIW, I was apprehensive about purchasing the TWF inserts due to cost. I am very glad that I purchased them instead of wasting time sourcing the material and fighting fitting them up. Nice machining and well worth the money.
richingalveston
120
galveston/Texas
I second the pvc inserts if you do not have hutchinsons. TWF pvc inserts are high quality. hutchinsons are flexible and easier to get installed, but cost more.
I would run steel spacers if you can get them. Or just check the aluminum ones for torque often until you are comfortable with them.
I would use 12 to 16 oz of any quality tire beads if you can't get centramatics. The centramatics you need are $299 for the set.
most of the balance beads are going to cost from $80 to $150 for all 5 tires depending on brand you choose.
I would not try to recenter my own rims if you still know the person that did your custom 20's then I would take them there.
you can probably get the rims, tires, spacers and balancers for less than the cost of 5 name brand off road tires (35 to 37 inches tall) that would fit the stock cucv rims.
