15KW Test Load Built From HVAC Heating Coil Pack
428gearhead
52
13
Martinsburg WV
I was looking for a way to load test my MEP802A and had an idea:
I happened to have an old heat pump air handler laying around. The air handler has a 15KW heating coil pack installed for aux heat. Now, 15KW is too much for the 802A, however the coil pack consists of 3 separate 5KW coils switched by 24v relays. The blower motor has 3 speeds as well.... perfect.
I hard wired one of the 5kw coils and the motor for now. It put a 90% load on the 802A.
In the future, I will utilize the 24v relays controlled with switches, and same for the blower motor. The case will be shortened, screens installed and will roll on a set of casters. I will update on the finished product when complete.
Jayhawk#44
148
33
Arizona
I saw elsewhere on here someone used relays and switches in parallel and series parallel circuit configurations to achieve many relevant KW resistance ranges. In DC electronics this is pretty straight forward. I’m not an AC electricity guy so I can’t say for sure if it’s the same math.
Later,
