16R20 XZL on M818
461
Sandyston, NJ
I am putting a set of 16R20 XZLs on HEMTT wheels. I was wondering if there are any rubbing issues on the front when turning. Any first hand experience would be great.
Andy1234
13
St. Louis, Missouri
Under compression, at full turn, the knuckles on the outer edge of the tire will rub the "c" shaped bracket on the rear part of the frame section. Remove the bracket and you remove the rub.
FWIW, only the passenger side rubbed on mine.
Andy
Alredneck
Banned
1,494
15
TN
They look sweet, when mounted! Andy has some nice rigs!
Andy I left ya a message on phone, im in TX headed to AZ wont be back to TN till the weekend sometime!
Does anybody know it takes almost all day to drive across TX! SSSSHHHHHH!!!!!!!!!!!!!!!!!!!!
jwaller
19
Columbia, SC
hemet rims need no work and they won't hit anything. 5 ton combat wheels will hit the steering gear box and hyd cylinder on pass side. you can adjust the stops to fix this though.
Rene M
Houston, Texas
Well we cant help, it its all we could take from Mexico? Slowly they are getting it back though.
If its any consolation i will buy you a beer if you sop in Houston.
