1941 dodge wc 1/2 ton
Steel Soldiers is supported by:
eased cpl
mercersburg pa
i am restoring a 1941 dodge wc 1/2 ton and I am wanting to put 9.00x16 tires on it stocksize is 7.50x16. some say that the 9.00x16s will not fit like the 7.50x16s, have heard they are interchangeable , I have seen them on other websites with the 9.00x16 tires and says they are stock could somebody let me know if they fit ? havn't had any luck thanks
FrankUSMC
20
Newport, NC
I have seen alot of photos of 90016s on the 1/2 ton dodges. To bad you are not closer, I have big tires (buckshot) on my WC1, the old owner put them on new rims from Vintage power wagon, then mounted them on the truck. I bought it from him about that time. There is about 4 miles on the tires. I would let you talk me out of them.
One of the few, Frank USMC RET
ETBaals
Blackwood NJ
Hi
the 750X16s are the stock size.
the 90x16s will fit the truck fine, You just do not want to mount them on original 1/2 ton wheels as they have very small lock beads.
You can use either M37/powerwgon wheels or WWII Dodge combat rims.
Where are you in PA?
I am in N right outside Phili
Ernie
