1950 m38 rims
jollygreen
Highrige MO
hey im looking for original rims for a m38 50-52 near st. louis if any one knows of any reply back and we can shuck and giv for them -scott
1,158
Are M38 and M38A1 rims the same?
skytroop232
Galena/ Ohio
Jollygreen,
I used to have an M38 and I can't remember what the difference was, but there is a distinct difference between civilian rims and military. If I can remember i will let you know.
I'm sure there is a current 38 owner out there that can help.
Bob
maddawg308
802
Appomattox, VA
You might have to get some repros - most of the originals out there are so-so in condition, I wouldn't trust my life to them. The repros are very nice, and the right size for your restoration. Cost is about $100 per.
SteveJ
Calgary Alberta
Most of the M38 and M38A1 rims were made by Kelsey Hayes. and most not all are stamped so.
WW2 jeeps used a split 2 piece combat wheel that was bolted together. Also used 600-16 tires.
M38 and A1 used a one piece wheel and 700-16 tires. The M100 trailer same wheel.
Military ones:
Some (not all) have a small 1/8 drilled hole in the bolt circle. (purpose unknown)
The valve stem lines up with a bolt hole on military ones.
The military ones wee riveted together.
Civy ones
Valve stem does not line up with bolt hole.
Were welded together.
may have some goofy clips or bumps to hold a hubcap.
Came in 15 or 16 inch.
What Ive run across over the years. Hope this helps.;-)
m38inmaine
101
Maine USA
Contact willy10 here on ss, I gave him a set and I think they are extra to his needs, they are original M38 wheels.
nat42gpw
winfield/ks
BILLF, i have 2 with old used 7.00x16 tires mounted on them that have the small hole and the valve stem lines up with one of the lugnut holes,and 2 with no tires mounted that have the small hole but valve stem doesnt line up with lug bolt hole,would be willing to trade all 4 for a good spare rim and tire for my gpw(combat wheel with a 6.00x16 ndt tire,dont care if its a repop wheel or original).
porkysplace
1,496
mid- michigan
This is a 10 year old thread , I would hope he found some by now.
