1954 M37 Distributor help needed
UnimogMike
Florida
I have 1954 M37 that has been converted by some one and I need to get new distributor cap and rotor for it. It still has flat head six engine with 12 v distributor and non resistor 12 v coil.
I am trying to replace cap and rotor, but have no way of knowing what Napa part numbers to use.
Please help
Mike
Blake
60
Opp, Alabama
M37 distrib cap
It all depends on what series/part number distributor is in your truck. Take a look at it and post back what series yours is so I can get you a rotor number. For the cap (most popular series listed below):
IAD or IGC series: Napa Echlin AL63
IAP or IAO series: Napa Echlin AL98
IBR or IAT or IAY series: Napa Echlin AL106
UnimogMike
Florida
Thank you, I will take a look and post it.
Also would you happen to know the firing order of the flat head cylinders?
Thank you again
Mike
Carter
Delta, Pa.
TM 9-8030 lists the firing order as 1,5,3,6,2,4, it was not marked on my trucks cyl. head or the spare I have although I have seen it on some heads.
SasquatchSanta
Northern Minnesota
Napa Part Nrs:
Dist Cap = AL 106
Condenser = AL 869
Rotor = AL 107
Points = CS 719A
If the truck has a standard M37 motor the oil pump should have been changed when the military distributor was replaced with a civilian distributor. The milirary style oil pump has an offset notch that receives an offset distributor drive shaft dog. The civilian distributor is not offset. With the military arrangement the distributor will only go in one way therefore you can't get the timeing 180 degrees off.
When you use a civilian distributor with a military oil pump it will knock out the distributor bearings. The reason I mention this is because it is one of those things that will give you fits.
Good luck.
