1965 m43b1 w/381
billyzz
rapid city sd
been fairly busy getting things sorted out
old vehicles HATE not being used regular
all sorts of weird crap pops up
the willys was the same way
use it all the time and it works like a top
ignore it for a few months and get ready to get yer hands dirty
doesnt help that is has been between -10f and +16f lately
no garage
billyzz
rapid city sd
i have used a 28000 one in my willys and could drive around in zero degrees with the window all the way open
these items are a bit pricey at $400
but i only need to buy it once
4 year warranty
billyzz
rapid city sd
you can get persnickety and try to seal every air leak on one of these antique rigs. or you can take the scorched earth /brute force approach (my personal technique) and pump such a massive amount of heat into the cab it doesnt matter how many leaks you have
billyzz
rapid city sd
BTW
i did use a 3 inch wide roll of gorilla tape and sealed the 1 inch gaps around the windshield
i dont care if it aint correct
something had to be done right now
sometime when i am feeling flush i will buy the correct seals and stuff
but its water/air tight right now
i hated the idea of water pouring down the dashboard straight into my transfer case/transmission
billyzz
rapid city sd
i have some of those super powerful little magnets that i took out of some old hard drives
i will attach them to those heat tubes
that way you can stick the tube anywhere ya want and they will stay
i am already thinking pointing one at the windshield
theres my defroster
billyzz
rapid city sd
things i have right now installed
block heater
locking hubs
12v
turn signals
wiper motors (need arms/blades)
have but havent installed yet
new powerking super traction tires
40000 btu heater
hndrsonj
Senior Chief/Moderator
366
Cheyenne, WY
Too bad I didn't catch it earlier, I have 5 power Kings I am getting rid of. (going to Superlugs)
billyzz
rapid city sd
on my truck
part A has a hole drilled in it to accept a padlock
the backdoors can be locked from the inside
same with the passenger
then a padlock for the tiremount/driver door
the two exterior storage compartments already have tabs for locks welded on.
billyzz
rapid city sd
I DROVE IT HOME!
and was instantly reminded of my willys jeep
slow
noisy
uncomfortable
smelly
and cool as all ****
i made a little movie with my phone but i cant do anything with it cuz my super fone is a POS
billyzz
rapid city sd
the tranny seems to be working fine
i just need to get used to it along with everything else on this rig
BTW the military complicated light switch is hooked up
took me ten minutes to figure out how to turn the headlights on ;)
billyzz
rapid city sd
i havent decided where the heater switch should be
i am not cutting a hole in my dash
so i have it laying on the floor in a baggy with the wires trailing to the heater
it works but it aint perty
