Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
i will be painting it because i hate the billboard painted on the sides
and the flat paint lets dirt stick to it like glue
toying with this civil defense scheme
and i have GOT to get better mirrors!
zero rear visibility
this thing is a disaster waiting to happen.
been looking into rear cameras even but havent found anything yet
__________________
pulled the transmission and transfer case to clean them up and replace all seals with modern double lipped ones as well as kwik sleeves every where.
lucas 50w synthetic
bearings look good
it turned out to say june 74 np435 on it
Having a hard time finding inexpensive multi groove pulleys and power steering pump bracket. And tension pulley.
I want to try and get air conditioning someday
Having to mix and match parts.
My 1969 engine didnt have any power steering,AC etc.
We found 2 different 318s that we swiped pulleys etc.
Just now i ordered a shim kit for the crankshaft pulley.
We will have to cut the inner wheelwell a bit.
And there is a small amount of welding involved for the upgrade.
I am right at $500 now
The only things still needed (i think)
Are new belts and fluid
I have decided that i only need the two lower upholstered cots and the other backrest.
There is already one backrest to use as a template.
Replacing the steel that someone cut out will be the hardest part.
And even that doesnt look all that tough.
I have found od canvas or vinyl for the seats
Its just a hunk of plywood and a metal frame.
I am thinking old bed frames will work great and be cheap.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
