1966 Deuce without starter relay
Jkuecher@
Sunset, Tx
I'm replacing the harness on my 1966 Duece does anyone have a diagram and/or pics of how the starter is wired. The diagram I have is for the starter with engine block mounted relay. My starter doesn't have that block mounted relay.
Jkuecher@
Sunset, Tx
I was watching a video by Tactical Repair and He mentioned the bell style starter solenoid, which is what I have, doesn't use a block mounted relay. I have a picture of the style starter on my 1966 if you would like to see it.
davidb56
1,237
Bonners Ferry Idaho
so its built in or attached to the starter like a chevy? they would still wire the same. a wire to the solenoid relay and the + cable to the large post. probably a1 or 2 wires along with the + cable connection for accessory and panel power.
