1971 M35A2 Four ways.. Help
ehinlein
17
Pelham,MA
Does anyone have any experience adding 4 way flashers to an M35? The directional unit now is silent, (no relay can) so I assume it's electronic. I don't have the number of the directional unit with me. Is there a turn signal unit w/ flashers that's available?
mangus580
282
Western NY
You might want to try reading the Operators Manual on the deuce. It has 4 way flashers. If you put the signal lever in the right turn postion, and slide the handle (or handle lock) out, it will click up another position.
BTW... I am moving this to the deuce forum, out of the website help forum. Also, you might try using the search feature, as we have discussed this before....
