1971 M35A2 injector problems
mikenpa
Washougal Wa
Hi Folks,
i took my deuce out for a drive this weekend and after getting back home, I let it idle for about 10 minutes, when I came back out it was missing real with puffs of white smoke coming out of the exhaust pipe!
How do you check out if I have a sticking injector, or did a head gasket go away?
Any thoughts would be great
Mike in Washougal Wa
marquardt2959
Tigerton,Wisconsin
1971 M35a2 injector problems
I have had good luck with the product Hot Shot secret. I used it as a preventative measure, to get rid of sticktion on injectors and turbo. You can find out more at hotshotsecret.com. I used it on my 3 M35a2, all are 71 AM Generals.
dittle
72
Albia, IA
Should be able to feel each injector with your hand and 1 or more of them will feel different than the other (clicking versus no clicking). If you had a laser thermometer you could shoot the exhaust manifold at each port and it will tell which piston isn't firing due to temp difference.
mikenpa
Washougal Wa
Hi Guys,
Thanks for the ideas! I was real tired last night as the M35A2 is a 1972 AM General!
Here is a photo of it and my M-105 Trailer when I was at Ft Stevens Or this August!
I will check out the truck this weekend!
Mike
