1990 M923A2 steering box AZ issues non responsive after installing new gearbox
ArizonaGasMonkey
Phoenix, AZ
I am trying to assist a buddy on his 1990 M923A2 Cargo truck as he is getting ready for a trip with his family.
Truck had a leaking steering gear box and the box was replaced with a tested unit that was tested by supplier prior to installing onto the truck.
The box I was told is an updated model which meant the hose ports hooked up a little different but lines are now hooked up and have been bleed to ensure no air.
The previous gearbox leaked badly but still worked.
He is in Maricopa AZ and his name is Chris. I asked everyone I knew about suggestions and am hoping our community might be able to make additional recommendations.
Chris (480) 283-4795
Any Help would be appreciated
Aaron
Suprman
664
Stratford/Connecticut
There are 2 different style gearboxes. If the lines hooked up different chances are he installed the wrong one. M939 and a1 use one style and the a2 trucks use a different one. They are not interchangeable.
tcbuhr
Maricopa
Do you know the part number of the a2 gearbox?? Trying to find one locally and not sure where to start?
Csm Davis
380
Hattiesburg, Mississippi
New A2
Old M939, and M939 A1 style
But not sure if you get the hoses in the right place why it wouldn't work?
Suprman
664
The two styles are not interchangeable I dont know exactly why not though. The m939
and m939a1 use a ross hydrapower box. The a2 trucks use a different brand.
cybrockway
-1
Effort, PA
Thank you for your help. Chris was able to get it going the hoses were backwards on the right side of the box. I appreciate your assistance. Aaron
Would you happen to have any pictures of this install? I'm looking to replace my A2 version as it's loose and non-adjustable for an A1 style that is adjustable. Thanks in advance!
jcollings
372
Jupiter/FL
Swamp Donkey,
Have a m923a2 steering box shaft seal leak, anyone you know is a reliable rebuilder? Or is it something that can be done like do yourself?
Swamp Donkey
The Engineer
119
Gray, GA
I'll be looking for one myself after a while, a rebuild that is. My Ross steering gear is leaking from the input seal, and after going through a couple Chevy steering boxes in my younger days, I feel more confident in someone else more qualified than me doing it. It's fairly straight forward to replace the seal but there's a multitude of other things you can mess up while you're in there. This is where I failed on the Chevy boxes. They didn't leak anymore but they didn't work either. :mrgreen:
My plan is to buy a new box so I have a direct replacement, then have the original rebuilt for a spare. I like spares and hate down time so this works for me. You could always just have yours rebuilt without buying another one. There was a guy in Macon that I had rebuild the Chevy boxes years ago (since I caused more harm than good) but I'm not sure if he's still around. He knew his stuff but didn't advertise as it was a side gig for him.
