1990 m923a2 stuck in 6x6
99nouns
9
Ocala, FL
Hello Rambo, welcome to the site.
How did you determine that your front axle is engaged?
Normally you neet to cut all 6 off the ground.
If you did that, please teach me too.
As far as the engagement switch at dash there also is an air switch at the transfer case which is a large washer connected to the Low Range arm below the cab, that switch might be stuck, if no problem there than you have to check the air cylinders on the transfer case.
PS also people here likes you to use your first post to be introducing your self before jumping into all the other fun problems...
MarcusOReallyus
237
Virginia
You will probably find you'll get better results on forums if you post in the correct place. There is a forum for 5 tons. This forum is for "Forum Tips and Tricks". Not many people pay attention to what's here.
Rmtaunton
Smyrna, ga
If it has always been this way your air lines going to tcase are backwards , common problem
