- 592
- 596
- 93
- Evansville, IN
Out of his league??? Had HMMWV for 5 years and not sure how anything works... Wow.. Radiator fluid.....That would be COOLANT.. Must be an Oregon thing. Id say you best pay VERY CLOSE attention to everything that is in this post.. YOU will need it.. Test your sensors, make sure your RADIATOR FLUID (coolant) is at the Correct level. And LEARN about your vehicle..We don't need another non educated person causing public issues that could hurt our hobby and further impair our ability to keep our rigs on the road. Next thing you know, your wheel falls off because you haven't checked your hubs and someone gets killed.. Please be a responsible owner.. Cmon ManCan't say for sure... I don't think it's out of your league. You're just on first base and heading to second. Big hitter on the bench here. Just be clear on sending the correct signs. (symptoms) Can't get home without runing the bases in order while playing smart and hard.
Watch out for less than top quality parts. Good way to get put out. OUCH
Check the play book (TM) to clear the possibility of grounding out and not seeing the gauges or anything working right. Really want to have them property grounded. Easy to execute before spending money.
When was the last time the waterboy check the cooler. That stuff could be nasty. Auh !
Lots going on here. We understand the need for a designated runner too.
Up in the peanut gallery rooting for team SS, and bmdupont, CAMO
Sorry if I hurt any feelings... Rough day... Good Luck..
