DrJekl
- 1
- 18
- Clarksville, TN
The only differences I found in the harness:
1991 harness does not have the temp sensor wire. (added)
1991 harness has the wiper washer wires in the headlamp harness (white and red, removed)
1991 harness has two light blue and two dark blue as stated previously. (tied these together)
1991 harness does not have the black out marker and drive light. This is a given but thought I'd mention it. I am not using the BO markers in the new bumper and the drive light housing is where the plug for my winch pickle is housed. (capped the wires coming from the CUCV front light harness plug)
1991 harness uses different color wires for the horn as stated. (spliced the CUCV horn and 1991 horn together)
Horn number two goes in the same area the slave receptical goes.
The overflow bottle has a mount the base of the bottle goes into on the CUCV core support.
Slave leads that go through the core support have to be rerouted so they do not interfere with the new turn signal light on the right side.
All are small issues to fix. My current delay is the radiator. The one I had serviced came back missing the nipple for the over flow bottle and I did not notice it until I had the radiator installed. It came back out and is back at the shop getting fixed again. My fan shroud was tore up on the bottom so I grabbed another from the shop and will replace it.
Bacially I have to route the temp sensor wire, plug in the harness to the firewall, finsih the radiator, get my WVO filter system back in, cut the new grill for the slave recepticle, and get all the little things tied in. Should be in business this weekend if all goes well.
No, I don't have photos just yet.
